EXIF Data
Josh_Houchin
Colorado Springs, Colorado
How can you look at someone else's EXIF data? When I see a photo I really like I would like to be able to look at the exif data to help improve my own images. How do you access this information? Thanks in advance!
Online? Many browsers have an EXIF reader add-on.
In your computer, Opanda.com
Lots of sites will strip it for privacy reasons (phones sneakily embed the GPS co-ordinates, hence why facebook strip exif)
For what it's worth, when I downsize my images to 'fit' the size requirements, Photoshop Elements is knocking off the details of the EXIF. But then, I'm doing a "save for web" operation. Perhaps if I go back to the lower JPG quality save method it will keep the EXIF info.
Elements "Save for Web" option is removing the EXIF information as a way to make the image file size smaller for the web.
Using the newer Photoshop CS releases or CC, the Save For Web feature lets the user decide if Save for Web will or won't strip the ExIF info.
I don't know if newer releases of Elements has the same option.
right click on image then click on properties then click on detail. you can see EXIF data in detail and you can change and remove exif data ..
Mac? Windows? OS? Software?
Windows 8 works this way, but I can't seem to be able to change data - only view and selectively remove it. I guess it uses the camera manufacturer codecs since it works with both JPG and NEF files.
