Robin Usagani
- Joined
- Jun 6, 2010
- Messages
- 10,347
- Reaction score
- 2,174
- Location
- Denver, CO
- Can others edit my Photos
- Photos OK to edit
Dao, using a bounce card seems to be VERY popular. Even our respected member Derrel thinks so. I never want to use a bounce card and definitely not stoffen or fong dong. I may use a bounce card if the room is not ideal for bouncing but I avoid it at all cost. Look at this link below. Also look at a few quotes I cut and pasted below.
http://neilvn.com/tangents/flash-photography-techniques/4-bouncing-flash/
"if you’re using the correct angle. And here I want to stress something again – shooting with an omnibounce at 60 or 45 degrees, should not be a default way of using flash."
"A key factor in both these images, was that there was NO light directly from my flash on my subject. All the light was indirect."
Basically if you add a stoffen or a bounce card, you are ADDING direct light. If you bounce your flash to the ceiling and wall behind you in an angle, that bright spot on the wall and ceiling WILL BE your catch light.
