Failed Cyanotype
Reece Hudson
Hello,
Looking for help on Cyanotype. I've followed the instructions, watched tutorials and done successful Cyanotypes years a go at University. However upon trying currently it just is not working.
I'm mixing the chems, equal parts and painting the paper and then leaving to dry. I'm then placing a digital negative over the image and using a UV lamp to expose the image. However the resulting 'imprint' remains yellow with no signs of blue, and upon rinsing in water the emulsion just runs off the paper.
Before it runs I can see the image on the emulsion in decent detail.
So far I have:
Changed lamps to different UV wavelengths.
Changed Paper
Varied or Extended the Exposure times.
Changed the Ph of the water used.
All to no avail.
Any help would be much appreciated.
What paper are you using?
Digital negative? What is this actually printed on?
Hello,
So far I have:
Changed Paper
All to no avail.
First was: Faber-Castel Sketch Paper
Second: Winsor & Newton Drawing and Sketching Paper.
I think you are underexposing.
We've (well, mostly lazy lobster) has just done objects like leaves, keys, and twigs. Once I get this printer replaced, we'll try some photos.
@Reece Hudson: I'm with compur and thinking exposure.
Hello Reece,
If you are still having some problems this might be of some help.
I use a face tanning lamp with 4 UV tubes, to make prints on A4 cartridge paper
The exposure for this one was 8 mins at 12" on Daler Rowney 220gsm paper
It was toned in Tea.
Cheers - Jim
