Film is transparent
Hertz, with that experience, I hope you continue to contribute to the forum!
Ron, I'm guessing you are indicating you use the zone method (Ansel Adams).
Someday, I will study that. Does it not require a good spot meter?
Look at my post count for an answer to that.
And my experience is a great deal more than most people realise - I posted my CV somewhere on here once ;)
And the same results as are achieved by the Zone system can be delivered by a much simpler method.
The Zone System is just applied sensitometry - but it can be applied to an excesive degree with no appreciable gain. There is a much simpler way of doing it that takes in all the variables and requires just two graphs for any film.
I will post all the info here - just as soon as I can get my blessed graphs into EPS format so they don't come out looking like cr*p when converted to PDF.
The zone system is living on the edge. Shooting for shadow details, developing for highlights.
Understanding the expansion and compression of your tones under different light conditions is where the secret lies. It's the difference of shadow to highlights that determine the development. Determine the exposure by your dark shadow with details, that will be somewhat just above total black.
To use the zone system you really don't need a spot meter, but instead be more consience of your metered areas. I originally learned how to do it using a Lunar Pro and eventually got the 5° spot attachment, then invested my first born in a Pentax 1° spotmeter. It just made the job easier, not any better. It takes some practice and alot of testing before you get control of your negatives.
Sugested traditional reading is Minor White's Zone System. It's not easy reading. There is a ton of information on the internet that will make it easier to understand and is better written for beginers. Then get the real bible, Ansel Adams, The Negative.
Here is a site that will help you do all the film tests and explains the zone system quite well... http://www.zone2tone.co.uk/techpagemenu.htm
Have fun and burn lots of film, that's the only way to learn.
