First time shooting in RAW
I've heard the 35mm 1.8G is the best bang for the buck for portrait work, I'd look into that lens. (I just ordered one too!).
Great! Thank you!
This example doesn't indicate that you need a new lens, it indicates that you need to pay more attention to backgrounds and compose your shots better. Large aperture is not the be-all end-all of portraiture. With two people in your shot, you'd likely miss focus on one of them by shooting at f/1.8.
Zoom your kit lens to 55mm and open to f/5.6. Get close to your subject for a tightly framed shot and place them so that the nearest background object is pretty far away. You will blur the sh!t out of the background. It's all about managing camera-to-subject and subject-to-background distance ratios. Perhaps difficult with a kit lens on a crop body while indoors, but shouldn't be a problem to find a suitable setup while shooting outside.
Great tip! Thank you. I will give it a whirl :)
Not a bad attempt at all. :-) Others stated pretty much what is what.
I would maybe edit a bit to give them that "soft" feel that people seem to like these days...
The vignetting makes it a bit darker than I want...but the people look ok, and I prefer darker anyway sometimes...however I learned what I see isn't what you guys see as my monitor sucks ass badly. lol
something like this...
Thanks for the advice. I often worry that my images don't look "polished" without a vignette. I do use a soft focus every now and then, but I try to mix it up a bit and not use it every time.
Great! Thank you!
The 35mm 1.8 G has major CA problems. It is also much to short to shoot portraits with, as was mentioned earlier. I had one.. and I gave it away.
If you want a good portrait lens for your APS-C body... get a Nikon 50mm 1.8 (or even better, the 1.4 Nikon or Sigma). This is the absolute shortest length you should use for portraits, unless you have massive experience. On a DX sensor.. you get a FOV of approximately 75mm... and this is still short enough to use indoors in tight spaces. An 85mm is better.. but on a DX.. it is too long for most indoor shooting.
