Fisheye lenses recommendation
Nikon 10.5 2.8.
I have had both the rokinon 8 and 12 as well. The distortion is different, the Nikon is a bit more "fishy", while the rokinons are a bit flatter. Both give you 180 degrees corner to corner. But the images I get from the Nikon are much sharper with better contrast. The Nikon is just a better lens. I found a mint one on ebay. It also accepts small ND filter at the rear so you can do long exposure daytime work. I am still working on trying to find where I can get them. Some folks are cutting them and making their own.
Your budget will guide you. I also have the 10mm full frame Nikkor and it is a spectacular lens. I haven't tested any of the third party brands. Be sure you don't include your feet in your images. :)
Over the years, I've shot with a couple of fisheyes. Back in my film days, it was Nikon's 8mm 180-degree circular fisheye. It was a lovely piece of glass. whose rearmost element extended almost to the film plane. To use it, the mirror had to be locked up and an accessory viewfinder used.
Here's one from those days:
Lately, I'm using Nikon's 10.5mm rectangular fisheye. It was designed for their cropped sensor cameras, but it appears that if I carefully remove the built-in plastic lens hood, it will become a circular fisheye on my full-frame cameras, since it has a 180-degree angle of view in all directions, except for the area masked by the hood. Haven't tried it yet, since trimming the hood will require a lot of precision.
A more recent fisheye shot, taken from about three feet behind the arch:
Many speak of "fisheye distortion," but in reality, a fisheye lens sees the world just as we do. It's a matter of viewing distance. If a fisheye image is viewed close enough, or printed large enough, when viewing it as close as possible (a few inches away, for instance), the 'distortion will disappear and the image will appear proper. Go figure.
The 10.5mm f/2.8 hands down is the best DX fisheye from Nikon. I've never used it, but I know plenty who have and they absolutely love it! Well worth the money.
The AF 10.5/2.8G DX Fisheye from Nikon is on my short wishlist of Nikon glas, too. Unfortunately I have two left hands and I really wonder how to get rid of that hood.
The AF 16/2.8G Fisheye as well as all previous fisheyes from Nikon have an excellent name, too. The really early and rare ones have builtin filters. Unfortunately they are mostly filters for black and white photography, though.
