adamhiram
- Joined
- Feb 6, 2015
- Messages
- 870
- Reaction score
- 588
- Can others edit my Photos
- Photos OK to edit
Just when I thought I was done discussing gear, I had to replace my flash trigger after suffering damage from a fall, so here we are again...
My Godox Xpro-N trigger (Flashpoint R2 Pro) works intermittently after falling from a height of maybe 2-3' and Landing on a soft padded carpet. About 25% of the time it won't turn on unless I squeeze the casing together. I've had it almost 3 years so I doubt it's covered under warranty, but I'm surprised to find out it's so delicate that it can't survive a minor drop onto a cushioned surface.
So after reading a number of reviews and recommendations, I replaced it with a Flashpoint R2 Pro MarkII. Overall, the improvements are pretty significant and it is a definitely a better user experience. These include backlit buttons, being able to turn the beep on and off remotely, controlling modeling lamp brightness, and dedicated buttons for each flash group making it much quicker to turn each group on and off. At the same time, it also feels like I am using a partially functional product that was never really finished.
Is anyone else using this trigger with their Godox/Flashpoint lights? Has your experience been the same?
- It is noticeably bigger to accommodate more buttons. So many buttons. Many of them seem redundant or non-functional.
- The Single Group Test button doesn't work on my TT600 speedlights, only bigger AD-series strobes (i.e. AD400Pro)
- The AF Assist Beam doesn't appear to work. This may be because I switched to a mirrorless body (Nikon Z6II).
- The Zoom feature doesn't work with my TT600 speedlights. This didn't work on my 1st gen Xpro-N trigger either, but it also didn't have a dedicated button.
- The backlight doesn't come on by default, which means I have to press an extra button to turn it on every time. Also, all the backlight button does is turn on the backlight. It doesn't turn it off, and pressing any other button serves the same purpose.
- The battery level indicator still doesn't show the correct level with rechargeable batteries. Alkaline batteries last forever, but I've had issues in the past with older batteries leaking and corroding the contacts. It's a shame they didn't account for common 1.2V Ni-MH batteries, such as Eneloops.
- The "Audio Buzz" button that turns the beep on and off is all-or-nothing. If I have a light set to full power, especially if I'm shooting with speedlights, it's nice to enable the beep on whichever light has the longest recycle time. There is no ability to enable the beep for just one group, and I definitely don't need to hear 3-4 beeps after each shot.
- Controlling the modeling lamps on my AD400Pro units doesn't work reliably either. If I deselect the group and press the Modeling Lamp button, it toggles all of them on or off. Sometimes I can select a specific group and turn that modeling lamp on and off, but other times the button does nothing. It's nice when it works, and pretty cool that I can even adjust the percentage brightness after double-tapping the Modeling Lamp button. However it does not work reliably, and it seems like I shouldn't need to go through these complex button sequences on a trigger with 23 buttons on it.
- The battery cover is loose and will probably fall off and get lost. This was a common issue with the 1st gen version, although mine didn't have that problem. I assume some gaffer tape will do the trick.
