For sale: Sony PXW-FS7M2 4k XDCAM Camcorder
von5
Up for sale is a Sony PXW-FS7M2 4K XDCAM Camera System with Super 35 CMOS Sensor in excellent working condition with no issues at all with this equipment.
This camera will ship out in a Sony PXW box with all the original parts, including the battery charger and manual, all the chords, DC plug in, etc.
I am the original owner of this camera... It is in excellent condition, showing some signs of use like minor scuffs or surface marks but overall it is very clean. Everything working smoothly just as it did on day one. Hours Meter (system) shows a total of 587H.
I swapped out a longer carbon fiber rail for mounting mic and EVF but will also include the original one, plus an extra carbon fiber at similar length. The only note to buyer that I want to mention is the tiny screw that attaches this rail...it is somewhat stripped and completely ridiculous for functionality. Philip Bloom and others have flagged this as a weakness in the build and the best solution is a Zacuto FS7 and FX9 Top Plate. This is a great add on.
Last note before the standard Sony description: If you aren't familar with the difference between the Mark 2 and original FS7, take a moment to do that research. The main fantastic addition to the Mark 2 was the vari ND wheel and the locking e-mount.
The breakdown details about the Sony FS7M2:
Expanding on the original FS7, Sony's PXW-FS7M2 XDCAM Super 35 Camera System is a flexible 4K camera system. Designed as a camera that is at home on productions as diverse as "Cinéma Vérité"-style documentaries, reality TV, commercial, and corporate applications It features a Super 35mm sized sensor that allows you to capture images with cinematic depth of field. The camera incorporates a stronger locking E-mount that is fully compatible with E-Mount lenses, and supports all electronic connections. The locking mount reduces lens play, and allows you to use most 35mm lenses including PL, EF, Leica, and Nikon via optional adapters.
This stronger E-mount is ideal for using heavier-long cine-zooms without the need for additional lens support.Just behind the lens mount sits an electronic variable ND system that provides a clear filter and 3 user definable presets. The variable ND can be adjusted to provide between 2 and 7 stops of ND. The camera can capture footage to optional on-board XQD media cards in either DCI 4K (4096 x 2160) or UHD 4K (3840 x 2160) at up to 59.94 fps or HD at up to 180 fps.
The camera records in your choice of XAVC-I, XAVC-L, or MPEG-2. However, MPEG-2 recording does not support the high data rates the camera can generate when shooting in UHD, and is limited to recording HD video only. The camera incorporates Dual XQD media card slots that support simultaneous or relay recording. An ergonomically designed handgrip provides control of many of the camera's functions and features an adjustable length support arm.
Connectivity: HDMI, Storage Type: Removable (Card/Disc/Tape), Media Format: XDCAM, Screen Size: 3.5 in, Features: Built-in Microphone, LCD Screen. Series: Sony XDCAM, Recording Definition: High Definition, Weight 4.4kg, Width 158.9mm, Height 247mm, Depth 245.2mm, Model: PXW-FS7M2.
Asking price: USD$7500 OBO
If you are interested kindly send me a message
allsales at protonmail dot com
Thanks for looking...!!!
