Dave Colangelo
- Joined
- Apr 27, 2016
- Messages
- 452
- Reaction score
- 159
- Can others edit my Photos
- Photos NOT OK to edit
I was at a new flea market this weekend and there were a few camera dealers which was cool. Lots of the usual over priced old Kodak stuff for interior decorating and a pool of broken brownies of various eras. There was however a few nice units and I decided to pull the trigger on a fairly nice Yashica 635. This is the TLR that shoots both 120 and 35mm film. It was complete with the full 35mm inserts so its good for both formats. I was out on a buddies boat later that day and decided to take the camera and run a roll of Portra 120 through it. In my haste at the flea market to get a good deal I failed to check the shutter speeds although I did check it for operation (it was working). Before loading the film I dry fired it a bit and realized that no matter what setting it was at (aside from bulb) it seemed to be firing at about the same speed. While this is hard to tell at the higher speeds I was not getting the usual unwinding at 1 second that I am used to on these cameras, 1/500th also seemed a bit slow. The pictures came out great but I decided to dig into the camera today and see what I can find. People were reporting problems with those era Yashicas getting stuck in bulb but a quick google did not turn anything up so the disassembly ensued.
Here is the camera (after reassembly) but with the front skin removed.
The whole lens mount unit comes right off the rails pretty easily
Some more disassembly gets you to the lens unit its self. This is fairly similar to the Rolleichord I have but the assembly is more enclosed.
Into the lens to see what was going on
Some more disassembly leads us to the speed regulation mechanism. On the surface no damage was evident and everything seemed in place.
Took it apart and Surprise! it was jammed up with nothing short of a spider web. Removed it, put some oil in and put it all back together.
Its now working like a charm, more adventures with it shall ensue!
(obligatory sample image from the day)
Regards
Dave
Regards
Dave
