Fujifilm GFX100RF
Any DR numbers to back that up? My suspicion here is they are talking about high DR camera like the Pentax 645z but, as far as I know the DR numbers for the Fuji shouldn't be as good because of the smaller pixel size.
If I'm reading right the camera has a claimed 13 stop DR, but there's more to consider, at what "signal to noise ratio". The K1MII boasts an ISO of 819,200, but the images produced at that ISO are mostly unusable in real life. I found this article which looks more in depth at the DR of the GFX100RF FUJIFILM GFX100 II Lab Test - Rolling Shutter, Dynamic Range, and Latitude | CineD
Also in re-reading your first linked article, it says that the ability to change aspect ratio only apply to JPEG - not RAW. Any image saved as RAW has the full sensor resolution. It also claims that the camera with it's fixed lens is "not" suitable for portrait work.
Another interesting link is Hasselblad will be releasing information on their new X2DII next month with a release date to follow in June. Hasselblad X2D II Coming on June 2025 - Latest Rumors and Updates « NEW CAMERA "Let the games begin"
DPR isn't as good as Imaging Resources, (and I have friend who works for DPR , so don't even try and bend that one.) Go to DxO. the 645z is still second on the list for DR after hasselbad. I just report the sources I trust. I'm not going to invest in making up stuff. Why you ask does the 645z still hold up you ask? Optical physics. Everyone else has tried to go for more MP. You will never see the kind of DR of the Nikon/Pentax (both of who used SNony sensors) again. Pentax K-5, (Nikon 7000) Pentax K-1 (Nikon D 800, D810) are the kings of Dynamic range, because they were design for the best compromise between resolution and pixel density. It's physics, not opinion. The laws of physics don't change.
"It is akin to comparing a 2008 EOS 5D Mark II vs a 2015 EOS 5Ds R that have at par DR even when former has 21.1MP while the later has 50.6MP.... difference was 7 years of R&D..."
Those cameras were way behind in DR, way behind their Nikon/Pentax counterparts. Canon didn't catch up in DR before mirrorless. SO you have your EOS 5D Mkii against the 5D both of which were pretty pathetic compared to cameras with Sony sensors. Honestly go to DxO and look.
Pentax 645z a total score of 101. The best Canon EOS R3 at 96. (And in my experience, you can see difference of 5 points or more, less than that is toss up.) DR of my K-1 14.6. DR of raw R3 14.7.. Canon improved over the 10 years, but still only matches the 645z with a 24 MP seamer as compared to 42 MP for the 645z. Not only that , my K-1 is 36 MP to Canoan leading 24 MP with the same DR. Canon is still behind, just not as badly.
The highest rate Canon is 19th on the list, with the same score as the Pentax K-1 and Nikon D800e. So ya, a lot of companies are producing product as good as anything Canon produces. If you want to push Canon, thier lens section is fantastic, they have always had great AF, and they have always been leaders in FPS. DR has always been their weakness. They aren't #2 (behind Apple as camera manufacturer) for no reason. Fact is DR just isn't that important. It's nice to have not have to have. But for the reason suggested, low light performance is critical, and larger pixels have better low light performance.
To me the camera to buy today for what you say you want, indoor iamges with no additional lighting, a quick Look at DxO suggests a second hand Nikon D850 might be your best bet. I don't own, one, and never have, but have run into people shooting with one, and from my experience it's probably the very top of the "most functional "camera field. Imperceptibly better than 645z and also 45 MP, so same DR as 645z and same resolution. Now that's an engineering feet that defies the physics and the Z7 is right behind it. The Canon R3 is up there, but with half the megapixels as the leaders. But the peak was the D850, and it's been all downhill from there. The D850 is still top 5 in DR and overall rating. And by the way, Im not even promoting the camera I use. I've never bought a Nikon. But Pentax and Nikon have used many of the same Sony sensors over the years and test within few points of each other.
I won't use a DR rating from site that doesn't have all cameras tested with the same protocols. DR rating from DxO compares all cameras with the same test. Imatest is different depending on the version used and who does the testing. Even so, the quoted test was a full stop of DR less than the leaders. The other thing IR has that others seem to ignores is comparison images taken in the same setting, and the actual test charts shot to produce their lw/ph numbers., lw/phh is the real test of resolution, not MP.) SO, as I said, when I have the whole picture, Imaging Resources reports on DR, lw/ph (Line width per picture height ) and side by side image comparisons, then I can make a more final determination, for myself. Before making final judgement I want to see if the lw/ph (real resolution) justifies the price, the DR and low light performance are excellent, and do I like the look of the images. But I wouldn't buy camera for any of that. Lens availability a the ergonomics top my list, A good photographer can take great images with any camera. (The corollary is a bad photographer can't take a good image with any camera, I've met a few.) Ease of use and an intuitive menu system are the most critical elements for many of us. With film people sometimes shot 7 EV DR and low resolution. Our standards have changed. But many of those old images are still really good.
Recognizing that DR is rarely an issue, even for shooting indoors in natural light, the Highest rating I've seen for the Fuji is 12.4 considerably under the D850's 14.8. 2.5 stops. Those number are from different sites with different testing methods, but that's the best I've seen.
Check it out.
DR is the rating they call "Landscape."
SO sad that the ability to use images for educational materials isn’t respected, but as I said, I’m not the one that would have to fight any lawsuit.
People, Mods have spoken on the rules, time to move on!
That’s pretty much what I said, thanks for summarizing succinctly.
To all: just a gentle reminder that the forum rules aren't up for debate. Thanks!
I have request for further clarification...Are links to YouTube videos without expressed consent are allowed?
You'd do well to review to review this thread's title: Fujifilm GFX 100RF.
You're wearing mods' forbearance tissue-thin. Why so obtuse? Move on!
As thread starter may I request that we keep to topic of the GFX100RF?
Those paying for this free service don't want certain behaviors based on their past experiences.
I am grateful for the link of the Singaporean camera reviewer. I got in touch with him about him keeping the camera or not.
We also shared notes on domestic pricing in our respective countries.
An interesting camera, but not one that would really gel with my shooting style. 28mm equiv is my least favorite focal length and I would be stuck using that, or throwing away pixels to use the other aspect ratios. The ergonomics seem a bit iffy as well, but it's hard to know without holding the camera. The OP's posted review seems to confirm many of the things I suspected. I was actually more enthusiastic about the crop modes, but now not so much. This just seems like a camera I would have a tough time wanting to shoot with.
"Paolo Dolina hi! hmm, i do have to return the review set to Fujifilm lol. Unfortunately the prices for the GFX100RF in Singapore is really expensive (USD5981 vs US SRP of USD4899) hence I am in 2 minds."
He hit the nail on the head. I really like the concept. A point and shoot MF camera, but it would have to be the right focal length. If it has 24-35mmm zoom, it would have been good on 56 of (and 42 of them were taken at 28mm) my best 753 images of 2019.
My 28-105 is my main lens for this kind of image, so I have more than expected 28 mm images.
Here we go, 28mm
2019-08-20-Nipissing-waterfall by Norm Head, on Flickr
It kind of reminds me of my Sigma DP2 with the Foveon sensor. Great images but a pain to use.
In any case, I always advise people to check the exif on their favourite photos for focal length before committing to one. I think that’s my take in this case. Just becasue I don’t make much use of the FL, doesn’t mean no one does.
In my case, lots of natural light natures shots I’d be interested in renting one for a weekend, just to see what I can do with it. That being said there are probably 10 cameras in that category. And the issue for me is, what would that image look like with possibly 2.5 stops less dynamic rage. I cant even guess how that would turn out. But, if everything turned out, it could be awesome, or it could be a dud. Definitely a try before you buy option. My Sigma DP2 I put fewer than 400 images on it. If I don’t like using it, the rest is irrelevant. The above image is hand held at 1/6s. No Ibis you say? Major problem.
This would be an interesting camera to follow just to see how many they sell and what they use it for. For me with a possibility of improving 42 out of 743 images, that would be some very expensive improvement on very few images, for a huge amount of money.YMMV
Here’s the guy I trust to evaluate cameras straight up.
Like say if my main intent is to take photos in personal, family and work events with best image quality possible without bringing a soft box or controlled directional lighting then it's a great camera that surpasses other fixed lens cameras.
I’m not sure why you say that. What about this camera makes it great for those images?
I did look at the people images… but nothing that stood out for me. I anything the maxim “If you arent already taking good images, buying a better camera won’t help.” comes to mind. Taking ho hum images with a great camera is a diservice to the camera.
Buy a Mac Mini and you ca put a 27”to 32” screen on it and get an M4 chip. YOu won’t believe the speed. My old 27” iMac worked until I took it to the dump. But in warm weather it overheated., and the monitor shut down. Then I was stuck. The MacMini lets me use whatever screen I want.
He hit the nail right on the head. Your not taking good photo's now, getting a more expensive camera isn't gonna help.
Anyway, are these cameras film or digital? I love film but cost's to much for developing and printing for me. I do my own and print my own and like most of what I get.
