Gary Fong Lightsphere AKA Fong Dong AKA The Tupperware
Robin Usagani
Denver, CO
What do you think of it? Real deal or just a gimmick? I recently went to a charity event and this photographer (probono) used it. I dont know why he chose to use the Fong Dong and use direct flash on people as oppose to bouncing it off the ceiling or wall. I dont put diffuser on my flash when I bounce the flash because I want to make sure all my lights are bounced and keep direct light to minimum. The only time I use diffuser is if I have nothing to bounce the light to (outdoor). I saw the pictures and they werent good (but mostly due to his skill, not the Dong). What is your take on it? Do you use it? Did you ever buy it? You got suckered in?
I don't own it, but it certainly does have it's uses. When you are shooting indoors and/or you have plenty of surfaces around for the light to bounce off of, then it can be great. When the light is bouncing, it's certainly better than straight on-camera flash, and with something like this, you get multiple angles of bounce, which can be good but maybe boring sometimes.
The biggest practical advantage to this thing, IMO, is that because it's bouncing the light all around, you don't have to worry about much when you switch from horizontal to vertical orientation. With many other flash accessories, you do have to change things when turning the camera, some of them make for terrible results when you turn them.
What I don't like about the LS, is that so many photographers think that it softens the light dramatically, and use it in situation where it doesn't help....outdoors for example. Sure, it will make a nice difference if you are two feet from your subject, but from 6 feet away, I don't think there would be much difference between it and direct flash, except that your flash has to fire with two or three times a much power because the light is going all over an only the forward direction is actually needed.
It's worth it just for the name value alone....just like the old Wang personal computers were. When you meet a hot, young thing in a club or bar, ask her if she'd like to come back to your place, to see your photo portfolio, and to maybe check out your dong....your Gary Fong dong that is...
It works every time (at least around last call).
Good points Mike! I like mine but it got to me because of the size. I can't fit it in the bag w/ my other stuff inside. It becomes another thing to carry around because of that. I got a sto-fen instead and it's more compact and much easier to carry around.
Using one doesn't make u look unprofessional. It also becomes people's styles. If they want to bounce it from walls or diffuse the light through LS
Interesting Mike. So you think its good to use lightsphere and bounce it off? I always take out my diffuser when i bounce (unless I am in a hurry). I feel the diffuser will give shiney forehead on my subject.
I got to give it to the guy. He must made millions selling these tupperwares.
Hello.. Im Long Doc Dong.. nice to meet you.
BTW, the photographer didnt bounce it with the Dong.
How to you mean? Unless he was outdoors, with nothing around, then he was probably bouncing the light off of something.
I meant, he pointed the dong to the subject. Yes it will bounce light everywhere but most of the lights are pointed directly to the subject.
Mike, doesn't the light bounce of the top if you use the silver cap and then throws the light from the side?
Ooh! Raggin' on another bad photographer!
Nice!
Ok.. i get it I'm not that good. But I know when somebody is good or bad. How come everytime I think you and I are good Bitter, you come and cheap shot me?
I use it for indoor flash shots, relatively close up (5-12 ft). It's somewhat better than pure bounce flash off the ceiling in that the light on faces is somewhat more even. However, it scatters a lot of light, so even with a good flash (I'm using the 580EX), you've got to be close. It acts a a straight diffuser when you point the dome at your subject, and it works like an augmented bounce flash when directed at the ceiling. You really have to experiment with it to get a sense of when it makes sense to use it, and when other methods are better.
Why can't you just ask the question about the diffuser, and leave the judgement of another photographer out of it.
Says you, on a beginner forum. It is to laugh.
No, they really were terrible. I saw them too. SL just post the link to the photos man. That guy was using his kit lens with random shutter speed and had blurry pictures, hand movements and all sorts of stuff. SL at least knows the basic, that guy didn't know jack ****. Sorry to say. He's probably just getting started though.
If the photo turned out good, I wouldnt be asking the question would I?
