"General critique" on my long exposure...?
Divegypsy
Belgium
Hi peeps,
I'd love to hear your comments on a long exposure of a church type structure I shot tonight on my Canon 550D, 18-55mm. Focal length 18, f16, exposed for 7min.
Where the lights are shining through, I can see some detail, but almost none toward the top due to the darkness.
Maybe try it again just after sunset.
Thanks for the feedback! In my defense: there is a lot less/almost no detail towards the top of the structure. But I do agree it could be better in that department. I'll definitely keep your tip in mind and give it another go sometime! You think light painting would be a good way to handle that problem too?
Yes, you have about twenty minutes after the sun has dipped below the horizon where you can still get detail in the shadows. I would also try opening up the aperture a stop or two.
Very cool structure. If this is close by, I would revisit many times at different times of the day and during the different seasons. Looks like fun.
I'll give that aperture a shot next time for sure! Thanks for the tip.
It's def close enough to check it out again and like you said very cool indeed! I wanna try other angles anyway because the scenery is cool all around. I just have to go and check it out during the day again first bc it was too hard to frame it right without really knowing/seeing what was around it...
I doubt you need to go f16, likely f8 will suffice thus allowing you to reduce the shutter speed. It still looks under exposed, I would do exactly the same thing except open up the aperture to f8 which should result with more detail in the shadow areas. Then, if need be, I would reduce the highlights in lightroom or photoshop. Nice composition though and cool structure.
