Doesn't the crop factor make the 50mm lens "act like" a 75mm lens in terms of field-of-view only, and not in terms of depth-of-field? The lens is projecting the same image no matter what camera it's attached to, but if that camera has a crop sensor it's just trimming off the edges, which wouldn't affect the DOF. The sensor can have other effects on the DOF, but theoretically speaking, if you had a 50mm FX lens and a 75mm DX lens and took a shot with each using the same camera without changing any other variables, the 75mm lens would have a shallower DOF but the FOV would be identical.
Right?
Nope!, not if you don't change any other variables.
If you go to
www.dofmaster.com to use the DOF calculator, you have to select what camera you are using, because the calculator has to take the crop factor into account.
Okay I don't know why I'm not wrapping my head around this today. I seem to be having an off week for my photo brain.
Why would simply cropping an image decrease the DOF? Crop sensors are crop sensors because the image projected by the lens is larger than the sensor, right? So the image projected by a 50mm lens is the same regardless of what body it's on, and the sensor is recording different portions of that image. So if it's the same image, why would the DOF change from camera to camera?
I knew that different camera bodies had an effect on DOF but I honestly thought that had more to do with the sensor design and capabilities than simply the crop factor.
I need to do some reading and figure out what part of the puzzle I'm missing. :scratch:
This is what I understand. Hope that make sense.
You are correct and on the right track. Before we discuss Depth of Field (DoF). Let's talks about Circle of Confusion (CoC).
In photography world, we need to define what is in focus, what is out of focus. As you can see, it is affected by many factors. So someone defined the CoC for us better understand in focus or out of focus..
CoC is defined that when the largest blur spot appears to be a point by human eye in a certain condition. Take a look at the following image.
Image from "http://www.cambridgeincolour.com/tutorials/depth-of-field.htm"
From the above image, when you look closer, how many dots are in focus? And when you stand farther away, how many dots are in focus? As you can see, they changed So if you develope a photo and view it in a very short distance, the "In focus / Out of focus" changes (=> so as DoF) (of course, if you enlarge the photo, and view it at the same distance, DoF also changed)
So for the CoC, they define the photo is developed on a regular photo size (8x10) and view it in a normal distance (about 10 inches).
If you take a photo with full frame sensor camera, without any modification, just print it on a 8x10 paper. (Paper A)
Then stand on the same spot and take a photo with a cropped body, without any modification, just print it on a 8x10 paper (Paper B)
You may notice the objects on Paper B is larger than in Paper A. Because it is enlarged. So the out of focus tree in the background may appear blurrier (CoC). In other words, the DoF on Paper B is narrower.
Example:
Condition A: Camera = 5Dmk2, focal length = 50mm, f-stop = 5.6 subject distance = 10ft ................... DoF = 4.25 ft
Condition B: Camera = 7D, focal length = 50mm, f-stop = 5.6, subject distance = 10ft ................... DoF = 2.62 ft
But wait a minute, how come everybody said larger sensor body produce a narrower DoF? It is because in order to have the
same framing, the photographer with a full frame body need to walk closer to the subject and that affect the DoF. So if you compare 2 portrait head shot type photos with the same framing (without any post processing), the one that shot with full frame body has a narrower DoF than the one shot with a cropped body.
