Graduated Beauty
kric2schaam626
Fox Cities, WI
This is a friend who just graduated college and wanted some pics done. Unfortunately, I noticed that the modifier is a little to close and blew out some spots on her face. Any other C+C is appreciated.
The framing is a bit off...or maybe the pose? A wider shot would have kept her fingers and arms in the frame. Having her turn at a bit of an angle then bringing her eyes to the camera may have also helped the pose.
Don't chop her arms/elbows like that :( Besides, I wouldn't know that she's just graduated if you hadn't told me. Her smile's sweet though.
Crop it tighter. The chopped off arms dont do much to improve the shot. Nice smile though. She looks happy.
I think in line with jowensphoto and DiscoJoe.....they already expressed!!!.....I feel....don't you see her face smaller in comparison to her body....more of the frame, that I think.
Here is my thoughts on it....
Little bit here and there with "as is" crop
Possible crop with the touch ups included
A local photog showed me his "method" for creating that look earlier this week. Short version is duplicate the layer, add a highpass filter on it....this part is hard to explain as it varies for each photo, but slide the slider till the threshold just barely starts to show color, then apply, then in the dropdown box where it says "normal" change to "softlight", hit Ctrl I to invert it, then zoom in to see the eyes well and pick eraser tool and set to appropriate size...opacity about 25%...go over complete eyes and eye sockets, nose, mouth,...basically the T, then set opacity to 50 ish and click 2 or 3 times on the eyes and go over teeth if present. brings back out the exacting detail (if there was any) of the original image as we want the eyes in focus at all times.
then there's more stuff in phase two, thats basically phase 1 of his method. Phase two, if desired, has another layer added, set to "multiply" reduced to about 50%, add gaussian blur, then adjust as needed for brightness/levels as it can darken it too much at times. Phase two isn't always used, just for a more "pow" effect sometimes. He does it very very well as he's been doing it for years....I'm just learning to edit people so I'm still practicing to get it right.
Seems like a lot, but it really only took like 5-10 minutes. Good "starting" point and can be fine tuned as needed.
One thing I learned is you have to be careful 'cause sometimes you can make blotches, depending on lighting used as well, so you have to adjust accordingly.
oh...I also ran it through my Noiseware Professional plugin....used the default settings. It is awesome for removing noise and adding a tinge of softness...without ruining the lines at all.
