Tee_bird
- Joined
- Aug 31, 2009
- Messages
- 67
- Reaction score
- 0
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- #16
Awesome comment, thanks!edit - ahem - really liking this shot by the way
hmm reading your exif off flickr I am impressed:
Aperture f2.8
ISO 400
1/100sec
An aperture that wide is going to give you a very small depth of field to work with - especailly in macro work. In this shot you have shown very good focusing in getting the eye in focus - though looking at it larger I would have liked to see the edge scales around the eye also in the depth of field as well - tricky though certainly.
I also like the lighting that you have in this shot - its clear and soft, with no real highlight problems at all which is really great to see.
As for next time what you need is more light so that you can use a smaller aperture (typically I do my macro at f13) whilst keeping a good low ISO and fast shutter speed. There are several ways to do this - reflectors can be used to direct more lighting onto your subject, that is a cheap and quick way and can work very well if you have the light to redirect.
The other method is flash. If your getting flat flash results from normal flash you will find ringlights give even flatter lighting, though the more expensive ones can have you set the sides so that they put different powers out so that you get some shadow depth.
Out of interest what flash setup do you have - just the popup or a speedlite of some form?
The flash I generally use is the popup on my camera.
