not as good as a real hdr.. but better then what you can ususally do in PS adjustment wise.
Is it really possible to have the camera take only ONE photo (not produced as RAW, but directly converted into .jpeg in camera?), tweak that in Photoshop using the levels and THEN try to have Photomatix make a so-called "HDR" from it?
I always thought that if you wanted to go with one photo taken only (click camera just that once according to your one set of settings), you would NEED to photograph in RAW (at least THAT!) so that you could get to the data and at least PRETEND in the RAW-converter programme that you exposed with three (or five or seven) different settings?
And after you have saved three/five/seven differently "exposed" (i.e. data altered to those different exposures) as TIFFs, you can transport them into Photomatix and have the programme create a HDR for you which you then tone-map !?!?!?
Better results can be had when you actually set the camera to three different exposures to BEGIN with, of course, but ... one jpeg only and then HDR :scratch: - I don't get THAT.
You can't make a HDR from one image.
Can you do HDR photos in PS? If so, how? Or is there a special program needed? Lastly, could you do something that looks similar to HDR in PS? Once again, if so, how?
Just a quick question:
took 5 shots for my HDR and shot it in RAW. I then created an HDR from the .cr2 files in Photomatix and then saved it as a .hdr -- I opened it in Photoshop and it looked nothing like it did in Photomatix
Any ideas? I also couldnt save the 32-bit image as a jpg and had to lower the quality.
