giveHOPEmakeCHANGE
Hi All! I'm new to this (forums in general) and need some help with my flash.
So I do not own a camera (since I can't afford one) but I usually use my friend's T1i with 17-55mm f/2.8. In low-lighting situations (like weddings) I usually use my flash to take better pictures. However, I was using my other friend's T2i and T3i the other day but my flash didn't work. I noticed that there was a crack on the plastic part (as seen on the pictures) but I do not know if that is the reason why my flash isn't working? I haven't tested it on the T1i yet but I would like to ask you all if the crack is the reason why my flash isn't working.
