help with B+W UV filters
mapgirl
Bellingham, WA
First of all, please, this is not a discussion of whether or not to use UV filters for lens protection.
I've got a new Canon 100mm macro lens for my Canon D60. I want a really good UV filter for it and I understand that B+W makes excellent filters. But they offer several kinds at several different prices. The explanations on Adorama B&H all make them seem the same. Can somebody please help explain the differences between them?
B + W 58mm XS-PRO UV Haze MRC (010M) Glass Filter
B + W 58mm Digital Pro UV (Ultra Violet) Haze Multi Coated (2C) Glass Filter #010
B + W 58mm MC (Multi Resistant Coating) Clear Glass Protection Filter, #007
B + W 58mm UV (Ultra Violet) Haze Multi Coated (2C) Glass Filter #010
Thanks!
The more-expensaive filters with the MRC, which I believe is their Multi Resistant Coating, are easier to CLEAN. And a bit more resistant to water-spotting, in my experience.
I have a few B+W 010 filters in 77mm, and they were 'spensive. I seldom use them, except in the spring when the trees are dripping airborne sap (like they are right NOW...zOMG, my windshield this AM was a MESS!!!!!!!! A fine,fine film of airborne tree sap was all over the freakin thing!)
Anyway..."some filters" used to be very difficult to clean, and lens tissue, T-shirts, whatever, would just SMEAR around and around and around in a vicious Catch-22 pattern...this is what the newer filter coatings have improved upon...ease of cleaning, and resistance to water-droplet pattern formation.
B+W filters are high-end...I would go with a low-priced B+W over the other "cheap-o" companies' (plural) highest-grade filter. A mid-grade B+W 010 filter is a fine quality filter. Mine have held up well over 10 years, but have not been used "a lot".
A second thing: some filters are described as "thin" or thin-mount or thin-ring, and are not really suitable for "stacking" a second filter on the front of, and may also not allow cheap or old lens caps to fit on all that well. "thin" filters usually cost more. I do not think they are worth it except in certain circumstances.
I run with B+W and Hoya filters. I can't really compare them apples to apples because each one is a different size or purpose, but both are good. If I were looking for a front filter for "protection" (which I don't do), I would look for a clear glass rather than UV. Modern sensors already have a UV filter, so an additional is moot.
With B+W, I would look at the MRC Nano coat ($63) and for Hoya, the Pro 1 Multi-Coated series ($35).
Always protect your lens by attatching the lens hood and using good common sense.
I use the basic UV BW. I read the muilti coating is delicate. I'm rough on my gear. Basic works fine for me.
All of mine have the MRC coating. I've never had a problem with it wearing off... I'm not obsessive about cleaning though. I pretty much only clean my lenses/filters when they get a fingerprint on them - and that usually only happens when one of the kids gets into my camera bag, lol.
Thank you all for your input! I decided on B+W 58mm Clear UV Haze with Multi-Resistant Coating (010M) . It was only $31.50 on Amazon. And for those out there who roll their eyes at using filters for lens protection, I completely respect your decision. But I shoot in dirt, in gardens, with stray branches (with spines and thorns) brushing past or right at my lenses. Yes, I always use a lens hood, but without a filter, I was getting way too cautious. And the filter I'd originally bought was too cheaply made and was indeed affecting my images.
I think you ought to be A-okay with the B+W 010 filter; B+W's filters are highly regarded. I would caution you though that when shooting toward bright light sources, the flat surface of a UV or protective filter can, and often does, create a reflection that the curved front element of a lens will often NOT have a problem with. Like, for instance, I shot my young son and his mother in front of multiple candles in a darkish room...a pretty common birthday scenario...and the B+W 010 filter on a Nikon 70200 VR zoom caused a bunch of flares...two for each candle flame...
I think that shooting right toward light sources is one of the most common scenarios in which the presence of a filter is actually likely to create a genuine, real, noticeable degradation of the image; in the majority of normal situations, I do not think a high-quality filter causes any significant negative impact on the image. So, on sunsets, and other toward-the-light shooting, I think removing the filter might be a good standard operating procedure.
Thank you Derrel! What great advice. It wouldn't have occurred to me at all.
B+W filters can come in F-PRO, XS-PRO, or SLIM. F-PRO are standard size filter rings with threads on front to stack filters. XS-PRO are a bit thinner but still have threads on front. I haven't been fond of "thin" threads as I've seen lens caps fall off (there aren't many threads). SLIM are their thinnest and designed for very wide angle lenses... but have _no_ threads on the front side of the filter, so you cannot stack another filter in front of a SLIM filter (when stacking it must be the front-most filter in the stack.)
See: F-Pro_Mount.jpg XS_Mount.jpg Slim_Mount.jpg
