Yes, if that is just a petal, then the magnification is fairly high, and f/5 is merely a moderate aperture. At higher magnifications, f/5 will leave parts of a three-dimensional object out of focus. Definitely, stopping down to a smaller aperture, like f/11 to f/13 would be a good step. You will read a lot of theoretical talk coming from internet talking heads about, "Loss of sharpness due to diffraction" at small apertures such as the f/8 to f/22 range, but the reality is that in single-shot macro work (meaning one-shot images, not multi-shot focus stacked images) depth of field almost always trumps obsessing over diffraction. How the back of the camera is aligned with the major plane of the subject also becomes a HUGE issue--and is one of the reasons tilt/shift macro lenses in the 85mm and 90mm focal lengths have been offered by Nikon and Canon for well over a decade.
Being able to tilt the lens to more closely-parallel the subject is one of the main uses for a tilt/shift lens, to more usefully "place" the plane of focus, for one-shot capture work.
Similar to the aperture theories so often discussed on-line,a few line pairs per millimeter more resolving ability at ISO 100 versus ISO 200 or 400, a little bit more noise at ISO 200 or 400 compared against ISO 100--all that is meaningless if there is visible detail that comes off looking unsharp or out of focus, or in this case, over-exposed and also out of focus. I personally think the small, white parts ARE a bit over-exposed (and they are, indeed, out of focus due to inadequately deep depth of field), and need some burning in in post to make them a bit darker.
It's pretty hard to overstate the need for SMALL apertures on close-range photos of three-dimensional objects like flowers. F/5 is just not a small enough aperture on most close-up shots, so strongly consider apertures like f/13 and f/16.
