Help with the lighting on her face?
Lmphotos
Missouri
$untitled-7714tfp.webp So another one from my practicing looking at her face does it seem gray to you? I am a fan bright skin and bright images but it seems when I backlight and then use fill the front of their faces are always too dark or a bit grayish. I would love to hear what other people see and think of it?
I don't see grey? It looks good to me...
Her HANDS are... kinda purple... but her face is fine. :lol:
The lighting is pretty good. Some people don't like the flat, contrastless lighting, but it's lit well.
The face isn't bad. You could use a warmer reflector or change the color temp of the shaded areas in LR or PS.
It's well lit, just not dynamically lit. Try a reflector
Here are some options:
A. This man's above
B. Match the WB to the temperature of the flash.
C. Match your flash with a gel to approx the temp you are shooting in
Otherwise the face is fine but the arms are cold.
A big silver or silver-gold reflector would work miracles here.
Just curious why would you choose the reflector over the flash? I initially had a gold reflector set up but did not like the look
