Stradawhovious
- Joined
- Nov 8, 2010
- Messages
- 3,241
- Reaction score
- 911
- Location
- Minneapolis, MN
- Can others edit my Photos
- Photos OK to edit
Part one.
For those of you who are unfamiliar with what this is, the HiViz sound trigger is a tool used in High Speed photography.
For those of you who are unfamiliar with high speed photography, here is a link to some pictures.... Image Search Results for high speed photography
Now on with the show.
I came home from work yesterday to find a box addressed to me on my door step from HiViz, which is a good thing because I have been impatiently waiting for this thing for THREE WHOLE DAYS.
Anxious to get the unit out, plug it in and get to snapping pictures, I not-so-carefully opened the box, and made it rain packing peanuts until I discovered the box of goodies near the bottom. I pulled it out, and found that the "some assembly required" actually meant "ALL assembly required". Seriously, it was a plastic enclosure with no holes in it for the controls, a bunch of electronic parts, a stripped circuit board and a handfull of wires. The buyer is required to be knowledgable with soldering electronics, and be handy with a drill .
Luckily I am both.
Another thing I noticed straight away is that there was no instruction manual on how to assemble this beast. I was able to locate one on the HiViz website, and was off to the races.
The Web instructions were very easy to understand and thorough. I got to wiring up the first resistor, and it went off without a hitch. Put the wires through the board, bent them over, soldered them in place and smipped the excess. No problem....... ont to resistor 2. The next resistor to be wired in was a 10ohm resistor. I couldn't find it...... turns out they gave me three 1 ohm resistors instead of two 1 ohm and 1 10 ohm.
Off to Radio shack.
[mid project rant]
Needless to say, I'm a little put out at this point. Not only can I not take it out of the box and play with it, I have to assemble the whole damn thing, wiring and all. Not only do I have to assemble it, but they don't give me the right parts.
[/mid project rant]
Once back from Radio Shack, correct part in tow, I got back to work. After a few hours of drilling, soldering, crying and swearing..... not to mention the Pizza break, I was finally finished. I put the box together, inserted a battery and flipped the switch.
Wonder of wonders, and miracle of miracles the light came on. I plugged in the included microphone (some assembly required of course), plugged in my radio trigger, clapped my hands together and the flash fired.
Honestly I was really surprised. I half expected that after all the trouble I had before hand, I would clap my hands, the unit would burst into flames taking the greater Minneapolis area with it.
I turned it off, put it down, went for a potty break and came back. Turned the unit back on and the LED wouldn't light up.
Surprise.
I plugged everything back in, and the unit still works, but the LED doesn't. I checked all the connections, everything is solid.... I must have fried it [the LED] soldering it in. [Sigh] C'est la vie.
A few things I have noticed about this unit;
- It is build really solidly. I feel that with teh plastic enclosure, if the builder does their part, it will last a lifetime.
- The sensitivity is not very sensitive. The unit goes from "nothing can set me off" to "a dog must have barked three blocks over" in 1/8 of a turn of the dial.
- It is a pain in the ass to build.
All in all, for a $40 bill I'm pretty happy with it, and cannot wait to put it through it's paces.
Coming soon..... Part Deux..... The taking of the high speed pictures...
(probably later tonight.)
Luckily I am both.
Off to Radio shack.
[mid project rant]
[/mid project rant]
Surprise.
