Helen B
- Joined
- Sep 16, 2007
- Messages
- 3,296
- Reaction score
- 467
- Location
- Hell's Kitchen, New York
- Can others edit my Photos
- Photos NOT OK to edit
18% gray is R=209, G=209, B=209.
That's about 18% down from white - ie about 82% reflectance. What is commonly called an 18% grey card is 18% reflectance, and after applying an sRGB or Adobe RGB profile it generally translates to around 118 to 120 - ie roughly half way between 0 and 255. That's because it is considered to be perceptually about half way between white and black, and both sRGB and Adobe RGB use perceptual scaling.
Just to be technically correct here:
One of the biggest misconceptions that photographers have - based on what others state as fact - - - is that a gray card is designed to be used to obtain correct White Balance settings. Gray cards are 18% gray and were designed to determine "Exposure" settings of normal caucasian subjects or grassy areas in landscape, that fall roughly into 18% gray tonality. A gray card is not neutral in colour.
It should be neutral, or close to it if it is called a grey card. Even the ones that are marketed for exposure should be neutral, for good technical reasons. Not all grey cards are designed for exposure, some are indeed designed for white balance. Grey cards that are marketed for white balance should be (and usually are) fairly neutral - as neutral as good white cards. They need not be 18% grey and often aren't - they are often lighter.
(As an aside, one of the earliest grey cards designed for exposure, the Neutrowe from 1939, was 14% reflectance, because this was found to correlate the best with the average reflectance of the test scenes that the researchers used. 14% is still considered a good value for 'average' scene reflectance.)
