How to take photo with colorful outdoor background, while indoor
SirCalvin
Hi, I'm Calvin from Indonesia.
Recently i just got back from my holidays, and was wondering how take photos while indoor, with outdoor background... Since result of my photo is far from satisfaction.
I tried using built in flash from my camera (sony e6300) but somehow flash didnt produce enough power (i already maximize my flash setting, btw)
I can adjust its brightness, but it will kill nice blue sky color on background.
So, what I'm actually want is, I still could maintain vivid color on background, while object of my photo (wife and kids) still bright.
Photo no 1, less color on background
Photo no 2, nice vivid color on background, but object is too dark
Thanks!
Thanks!
Set your camera to expose for the background, manual flash to expose the foreground subject.
Many cameras with built-in flashes do not output enough light. Try getting closer to the subject. Or buy a separate flash with greater output.
Both comments above are doing the same thing. They compensate for the difference in dynamic range. Unless you use an Incident meter you'll have a lot of trial and error on the first option. I'm not familiar with your camera but I'm assuming it offers TTL, a better way to go for on the fly flash correction. Here's a more detailed read on the general use of TTL The Beginner's Guide to Using TTL flash: How it works, why it fails and how to use it
Just be aware that as Alan mentioned above There are limitations imposed by your flash output, and sometimes you have to adjust both the Flash EV and the camera EV to balance your background and foreground.
You meant focusing on the background, then slightly bring the center to the object, and hit shoot button, i did try that, but seems not working
I would suggest another approach. I use a TTL flash
that I will fine tune with the EV compensation option.
This i will google it. Thanks!
Thanks 😁 lots of new vocabulary to me, i will google it too.
No, I meant what I wrote. I do not understand what you tried.
As for flash exposure, though, anything that properly exposes the foreground will work. I said manual because I find that as long as I know the guide number (or numbers, in case of multiple units,) the exposure I want is simple to calculate. That could be in automatic, manual, or through the lens modes.
Couple of ways to do this.
One is get more powerful external flash(es) to expose the foreground the same as the back ground.
Second is to take 2 shots, one exposed for the foreground and one for the background then use something like photoshop or light room to merge the 2 images.
Your camera may have a setting to bracket expose several shots quickly to make shots close enough to merge them easy.
I don't think the built in flash is powerful enough to even up the exposure difference here. You probably need a speedlight to even up the exposure difference.
It's a good idea to use your in built light meter to see what the EV difference is between the foreground and background. There's a good tutorial on flash photography here Strobist: Lighting 101: Introduction
As it is, all you can really do is raise the shadows in post, which might give you an acceptable shot.
The built-in flash is simply not strong enough to compensate for the full daylight outdoors.
As for setting exposure for the background, the way to do that is to meter the shot without the subjects, and note the settings the camera uses. Put those settings in manually to force the camera to use them. Then take a few shots with the subjects in place, using different flash power settings. You'll get several pictures with good background and various degrees of subject light. If none are brightly lit enough, then you need a better flash than the one built into the camera.
According to this review, the onboard flash for this camera is really weak. Sony A6300 Review - Flash
As to the existing photo, it's an easy edit in LR to correct. If you saved the raw file, it's even easier.
