hopdaddy
- Joined
- Apr 14, 2009
- Messages
- 536
- Reaction score
- 119
- Location
- Hotlanta,Ga
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- #16
I think even on camera flash would help a bit.
Basically you want your shutter speed or flash duration to be about 1/1500. If it is a bright and sunny day then you can just use your shutter speed. If it is a darker day, then what you can do is bring in your flash (preferably off camera like a vivitar 285hv). All you have right now though is the one attached to your camera, this should be more than enough to capture the motion though as most flash durations of the built in variety are capable of just about peaking at 1/1000 or 1/1500.
Essentially set your shutter speed to the proper sync speed (1/200th for canon, 1/250 for nikon is generally accepted), then use the flash (this is basically your new shutter speed) to light the scene.
When all is said and done you should be able to stop the motion of the bird, but keep some minor blur in the wings for movement sake.
Hope this wasn't too confusing!
Confusing no, the light bulb just lit(pun intended)..makes perfect sense now, the flash becomes the shutter(so to speak) thanks....practis time
