I Don't Think I'm Using This Flash Right
Thanks everyone for your input. So I what I'm getting is that if I use the white card, I shouldn't be pointing it at a 45 degree angle at the ceiling but it should be straight up? The first picture was at 45 degrees.
Depends how high the ceiling is and how far away your subject is. Aim your flash to put the light where you want it (after the bounce). Putting up the white card will bounce some of the light toward the front of the flash head.
Use a stationary still life subject that won't move (and won't get bored) and take 30 minutes to try various bounce angles, card vs no card etc. It's all about bouncing and angles...once you start to 'see the light', it's shouldn't be too hard to get the hang of it.
What Big Mike is talking about is what I was talking about earlier: experimenting to find a really pleasing, good bounce method. I once was shooting some maternity nudes in a large bathtub filled with green bath-salt-colored water in a small bathroom with a big tub. The room was only about 8x6, but with a high ceiling of around 10 feet, and a three foot "separation wall" coming down from the ceiling and separating the tub from the remainder of a large,long bathroom. Normal forward-facing bounce made awful light. To the left was a big picture window covered by a cool, lavender-ish fabric blind, and that was out of position and sent cool,lavender light away from the subject. The tub was a Jacuzzi-type, big,deep,and oval in shape. Bouncing off the back wall was too close and over-shot the subject. I kept rotating and clicking the flash head around. Finally, I zoomed the head to Maximum tele, concentrating the beam, and firing about 3 feet below the ceiling, to my left and backwards. The light went up, caromed off the wall, and then hit the basically 8 x 6 foot x 3 foot separation wall and made a HUGE "light box" that was extremely soft due to the 48 square foot "enclosure" located only about 9 feet from the subject!!! it also created beautiful diffuse highlights on the surface of the green-tinted water. The quality of the light began as BAD, then got better, and then finally after about 20 test shots, with "just the right" combination of beam concentration, unusual room construction with the 3 foot "deep" wall "divider" that kept all the light within the "mixing chamber", I had the equivalent of a huge light bank at my disposal.
One of the biggest issues when doing straight-up bounce flash is the tendency sometimes for saw hot, raw light to blast out of the very sides of the flash head, and strike the subject directly, and cause a very unattractive "hot stripe". With really, really powerful flash units like the Metz 60-series potato mashers or the Sunpak 622 Super, there can be some MAJOR, major problems when the flash is bounced and any part of the Fresnel lens is even remotely pointed toward the subjects!!! This can happen even with less-powerful flashes like Nikon's old SB-16, with which the hot,raw, untamed light that escapes right at the edges of the Fresnel lens can be a real PITA at times. The solution is normally to make SURE that the face of the flash's Fresnel lens is not angled toward the subject, but definitely angled away. THe closer you are to the subject, and the more-powerful the flash is, the bigger this problem is.
Another tool that can really help avoid this hot,raw light from moving directly to the subject is to use a "flag", like the Honle brand "wraps", which are dark fabric with Velcro to hold the wrap in place, and to "flag off" stray light. Anyway....bounce flash...it can be done a lot of ways. I just want to emphasize that the degree of ZOOM used can,at times, be a huge make-or-break factor, and there are times when it is best to use a white diffuser cap, like a Sto-Fen or the Canon or Nikon factory-supplied ones as shown in Kundalini's photos, or lacking that, sometimes it's good to use the flash with the built-in 14mm ultra-wide-angle diffuser pulled down and into position, to spread the light as widely as possible. Other times, "foofing" (Google it), using telephoto zoom flash and bouncing off of distant or very high ceilings/walls and using elevated ISO's of 1,000-3,200 can be just what the Dr. ordered.
Great post Derrel.
Try learning this stuff with film. :lol:
Sometimes I feel like I have to take way too many test shots. If I had shot in the film days I'd probably burn up a roll for each setup. :(
Turns out there is more to shooting models than just getting them half naked. Who would have thought?:er:
If you want your photos to look more professional, shoot in a better location or use some backdrops (and also learn to use the flash, but I think thats been covered by others already ). Half naked chicks shot in cheesy bedroom settings scream "upstart internet porn"
As for the bounce card, it can be useful when you need to increase the ambient but still want to throw some fill directly on your subject.
Watch the video "The President's photographer" on Netflix. Pete Souza is shooting with a Canon 580ex. Almost every time you see him shooting inside of the White House, he is shooting with the head straight up and the bounce card out.
if you bounced the light from the left of you, why is your right side illuminated? NOT A BAD THING....just curious ;)
Derrel, you are SOOOOO helpful!! :hug:: You have a nice creative flare!!
If he was standing in front of the model and bounced the light of his left - it should hit the models right.
The white card is mostly use for putting a catch light in the eye when shooting outside
I'm sorry, but that shows an extreme lack of understanding.
Why would you shoot the flash up into the sky and then use the white card to deflect a small portion of the light forward for a catch light?
If one simply pointed the flash forward, you would get the same catch light, but the flash would only need to fire at a fraction of the power.
Now, if you're indoors, then yes, the white 'bounce' card can be used to split the light. Letting most of it go up to bounce off the ceiling, but also directly some of it forward, directly to the subject for fill light and catch lights etc.
In fact, most of the flash accessories are made to do the exact same thing....Omnibounce, Lumiquest 80-20 etc.
I was thinking the same thing Mike....
