You "need" to take it? If this is some kind of class, you should get the info you need from your instructor. There aren't a lot of choices for infrared film these days. It can be done digitally with the right kind of filter. Aerial photography is its own specialty, with specialty equipment. It's unlikely you'll be asked to buy it. To answer your question, you'll have to be a bit more specific about what you're doing.
Aren't shutter speeds for IR measured in seconds? I was under that impression?
Okay. My husband was an aerial photographer for a couple of decades and shot infrared film for the occasional mission when it was needed. Originally IR film was valued for its ability to cut through atmospheric haze. It gained favor with fine art photographers because of its unique look.You "need" to take it? If this is some kind of class, you should get the info you need from your instructor. There aren't a lot of choices for infrared film these days. It can be done digitally with the right kind of filter. Aerial photography is its own specialty, with specialty equipment. It's unlikely you'll be asked to buy it. To answer your question, you'll have to be a bit more specific about what you're doing.
This is a project for a professor, but it's my independent research project and I'm applying for grant money to buy what I need. The idea is to create infrared images of a landscape using a helicopter drone that I also intend to build. I need advice about what camera to purchase in order to get good infrared imagery.
