Derrel
Mr. Rain Cloud
- Joined
- Jul 23, 2009
- Messages
- 48,211
- Reaction score
- 18,936
- Location
- USA
- Can others edit my Photos
- Photos OK to edit
Okay, the "NEW" Canon flashes use the E-TTL II protocol, which is supposed to be better than the earlier protocol, E-TTL, when using newer flashes like the Canon 580 EX II, the "II" meaning the newer, second-generation Mark II variant of that flash, and with the very latest RT 600 flash.
Newer Canon cameras, like the 7D, and the later EOS 1-series cameras, have color-evaluative light metering capabilities, whereas the earlier cameras were color-blind, and went STRICTLY by reflectance value (18% gray).
So, a few questions: in the early days of digital, I read about a LOT of very inconsistent E-TTL results with the pre-II flashes like the 580, and the "older" cameras.
But then, E-TTL II came out, and well, it was alleged to be better, and on the 20D and 5D, I found E-TTL flash with the 580 EX-II flash was sort of okay. What I am wondering now is how E-TTL II flash protocol, and an E-TTL II flash unit, work together with the color-aware, latest generation Canon bodies, like the 7D and 70D, and the 5D-III,and so on.
At one time, E-TTL flash was HYPER-SENSITIVE to the AF point that was in use, and the subject that was underneath that AF point. I'm wondering how much that is true today, with the latest flash and cameras, or if the focus point in use weighting is still as strong as it was, and if it's still as prone to blowing things out as it used to be, or if they've managed to get that issue more under control now that the newer bodies are measuring not just reflectance, but also are reading color values.
