Redbiscuit
Hi all, Is there a trick to shooting through glass, and not getting a reflection? (no flash). Thanks!
A polarizer "reduces" reflections... sometimes QUITE substantially. You typically will see some hint of a reflection, but with a tuned polarizer it's usually fairly subtle.
If I'm shooting a car, I find that *usually* the front window is made well enough that you don't get the pattern. But the back windows often will show the pattern.
Also a polarizer creates un-even effect if it's used on a wide angle lens.
