Mike_E
- Joined
- Jan 26, 2007
- Messages
- 5,327
- Reaction score
- 266
- Can others edit my Photos
- Photos OK to edit
An 8X10 Graphmatic (that didn't scratch) would be pretty cool.
I now see that you just want to make a weird gizmo rather than answer a practical photographic desire, so I'll answer in that vein.
Another common issue is film/GG registration. Because your System 1 would have quite a large mismatch between the plane of the film and the plane of the GG you would probably want a little quick system to rack focus out that fixed amount after focusing on the GG
Good point. If the OP does not have much experience shooting large format then I suggest he get a fair amount before diving into a project like this. I would even suggest that he head over to the large format photography forum as he will reach many more people who are familiar with large format shooting.I don't know how much experience you have with LF
Your film curvature test isn't really about damage, but about the resulting curvature set at the time the film is exposed - which may be seconds after it comes off the roll. Film flatness is already an issue with conventionally-used sheet film, and existing large roll film aerial cameras can use vacuum flattening. You could use vacuum flattening via a perforated GG.
Another common issue is film/GG registration. Because your System 1 would have quite a large mismatch between the plane of the film and the plane of the GG you would probably want a little quick system to rack focus out that fixed amount after focusing on the GG - not dissimilar to the idea of racking to 'chemical focus' in the good old days of my youth - ie the 19th century [sic​].
I don't know how much experience you have with LF or how much LF film you use or want to use. Once upon a time I would have suggested trying Quickloads with a GG-modified holder (a holder with a GG and dark slides on both sides). That system would still be quick and light, and would get round the curvature set that roll film would create. You would not be the first to design a reusable Quickload-type system for holding standard sheet film. It would also make switching film or switching development easier.
Remember that LF aerial roll film is thinner than sheet film for a good reason.
If you stick sheets to a long roll backing, how will you avoid feed problems at the leading edge of each sheet (which will be wanting to curl up)? Not insurmountable, of course, if going one way, but more of a problem for your reversible idea. You may also have problems with the difference in relative length when rolled and when flat. That would be solved by fastening the leading edge only.
I guess that when doing a practical evaluation you have to ask if your whole system (camera to print) gives you the quality you want when compared to, say, a Mamiya Press shooting 6x9 film with the very good holder that those Mamiyas use. Will you be printing optically or scanning and printing?
How does this not scratch the emulsion as it grinds across?If you want the film to lie flat, your system should probably arrange so that when the sheet is in position to be exposed, the tensions on it tend to curve it in the opposite direction to the curve it takes on your "rolls". The Mamiya RB/RZ system places the rolls behind the film plane, for example.
Eh? It would be right on top of the GG. The film would be unspooling from the back of those tubes, not the front, in case that was unclear. And I would rig up some sort of system so that film actually rests inside the tube (maybe 2 nested tubes? Not sure yet), for light protection anyway, so the feed location would always be constant. Metal guide rails and/or something like the air pressure flattening system would then make the film less than 1mm from the GG.With his design the film plain will be so far back from where the ground glass normally is
I borrowed a friend's for a couple months. So a little experience. Neither none nor a lot. I realize this may lead to me making dumb mistakes, but I will learn most efficiently if I am forced to build with a bit of a challenge. The main goal is fun and learning and a unique product, more so than never making a single mistake and getting it all right the very first time. *shrug*Good point. If the OP does not have much experience shooting large format then I suggest he get a fair amount before diving into a project like this. I would even suggest that he head over to the large format photography forum as he will reach many more people who are familiar with large format shooting.
Arista Ortho Litho Film 2.0 24 in. x 100 ft. Roll | Freestyle Photographic Supplies
for example.
Develop in dilute rodinol 1:75 or greater depending on contrast. Could probably be processed in an open drum dipped into a tray and continuously agitated by rotation; 10' roll length could be developed in a 4' drum, and 5' lengths fitting inside a standard 55 gallon shipping drum.
Be prepared to go through a LOT of fixer.
^^^ LOL - well? the OP asked!
I was thinking that with an xacto knife a strait edge and a leather hole punch I could turn it into 35mm film on the cheap.![]()
Oh okay, no that makes perfect sense. I assume you could make the sides of the plate rounded too to prevent extreme radius bending.Uh, the RZ/RB system is hard to explain, but the emulsion is not dragged across anything. Here is a crude picture:
