CCericola said:It used to be that wedding photographers were near the bottom of the barrel. Right above school photographers. Not so today. That is why you are out of your mind to start shooting a wedding without knowing what equipment to bring. A pro photographer shoots their first wedding after being an assistant for a hundred or so weddings. Then you become a second shooter for a couple of years. By the time you are ready to be the lead photographer you should know what you are doing. There are no short cuts. Think about that before you put someone's wedding day at risk. Now if you say you are ready then put your money where your mouth is. Post some pics and prove us wrong.
I'm not going to tell you what lens to rent. You should already know that.
Let's give the OP the benefit of the doubt and assume that she has already scouted the venues, met with the Deacon/Rector to discuss the church's "Do's and Don'ts" list, knows where to stand, has done some light-metering so that she has a baseline for approximately what her exposures are going to be, and the ten-thousand and one other little chores that need doing before the big day.MLeeK said:That f/4 lens is really going to hurt on your camera if this is in a church. I'd most definitely look into adding a flash. Is there flash photography allowed during the ceremony? Most churches do not allow it and many to most require you to be behind the last seated guest during the ceremony. You are going to NEED that70-200 and the f/4 may just shut you down in an average church.
Make sure you go scout the church first so you aren't getting hurt. You can use your kit lens for the wide angle in all of the other images with a flash, but that ceremony stuff is the stuff that can kill you. Make sure you know what the church's regulations are about where you can stand and if you can use flash during the ceremony.
The reaL question is: Does the OP even know how to use flash... if it is allowed?
Before someone becomes a pro wedding photographer, they have their first wedding shot and not all of us on here are fully equipped with all the lenses out there. Neither do all of us know what is "best" simply by not having enough experience. So do not be so sarcastic. I will do fine with what I have AND with a lens that I will rent. Thanks!
Good luck to you.I'm sorry, let me get this straight. You're photographing a wedding, and you don't know which lens is 'best'? Then why are you photographing a wedding?
Wow thanks for replies and being so encouraging and supportive! Way to go!
Now let me get this straight:
1) i DON'T claim to be a pro
2) Not all people are able to afford a PRO
3) when people can't afford a PRO they go with what they can afford
4) The people who booked me have seen the photos I have taken before and they liked what they saw
5) for the money they offered me (not much at al) they are not expecting much
6) they are well aware that I have never photographed a wedding before
7) I WILL do my best
Any more questions? Or may be someone will finally give me their opinion on the best lens option instead of telling me not to photograph a wedding coz I have never done it before and I am a newbie?
TheLost said:I would splurge and rent two lenses..
Nikon 17-55 f/2.8 (The Sigma is also a great lens and you may be able to rent it cheaper.. the Nikon is just better).
Nikon 70-200 f/2.8 (the VR1 will be cheaper to rent if they have it.. and will work awesome on your D5100).
(You say you have a 70-200 f/4... but i don't know what brand that would be.)
You'll need the 17-55 for wide shots and NOTHING will give you portraits (at a wedding) like the 70-200mm f/2.8. Most wedding photographers i know will give up their spouse before giving up their 70-200 f/2.8,
Stay away from any 24-70mm on your D5100 for weddings. It will work, and the Nikon 24-70 is one of the best... but its a hard to use range on a crop sensor camera.
Have fun... and good luck!
They might say that... but... people tend to take weddings seriously. Its that whole Mr. Right / Cinderella thing.. It's something you don't want to mess up.for the money they offered me (not much at al) they are not expecting much ... they are well aware that I have never photographed a wedding before
