reg
- Joined
- May 28, 2008
- Messages
- 1,487
- Reaction score
- 1
- Can others edit my Photos
- Photos OK to edit
Eh, to me hoods are more of something that looks cool.
PROTIP: They aren't.
I have clear UV filters on all my lenses for protection. While the hood can provide additional protection for the lens, the main purpose is to prevent reflected light from creating problems like lens glare. This is primarily a problem outdoors, but occasionally can happen indoors. If you plan to use your 50mm indoors, you probably don't need a hood for it.
"Why wouldn't you put a hood on is the question...."
For me, because using a lens cap with a lens hood is a pain.
You could not be more wrong in everything you just stated. A hood is not used to look "Badass" and it won't do what a UV Filter will do. Even without the hood you will get lens flare from a UV. a hood will eliminate that. Hoods are not meant to look Badass or meant to take up space. they are meant to help your shots from getting lens flare.
I don't believe so.
Lens hoods may prevent lens flare, but I already said that, and it doesn't do it significantly.
And in all my outdoor shooting, I've only had one lens flare problem.
Hoods can take up too much space for just that.
Real protection, not just the feeling of protection. On one of the forums (I believe it was Photo Camel but I'm not sure) someone recently posted a personal example of why a hood is protection and a filter is not. When he dropped the lens it broke the filter. After he took the pieces of broke filter out and removed the filter ring, that was now very tightly wedged on the lens, he found that the glass from the filter scratched the front element of the lens quite significantly. He also discovered that the filter ring had bent the threads on the lens barrel as well. Lens ruined.
If I owned L class, I would too. I do use a hood, however IMO they are best used in combination. If I had to choose, I would definitely go with a filter.The second problem with filters for protection is the filter themselves. Let me guess, this is the quality of filter you are probably talking about. This is what most people spend and get.
http://www.bhphotovideo.com/c/product/72715-REG/Tiffen_58UVP_58mm_UV_Protector_Glass.html
Like everything in life, you get what you pay for.
This is what they should be looking at if they want any kind of filter.
http://www.bhphotovideo.com/c/product/156799-REG/Heliopan_705886_58mm_Digital_Glass_Filter.html
or at least this.
http://www.bhphotovideo.com/c/product/180664-REG/B_W__58_mm_UV_415_UV_Blocking.html
Quality matters. Especially when you are putting a piece of glass in front of a lens.
Buying cheap filters is like putting Walmart's cheapest tires on a Lamborgini and wondering why you don't get decent performance. Me I own a lot of L glass. I protect it with a lens hood at all times and feel quite confident of it. I also didn't pay the money that an L lens costs for the quality only to degrade it with a piece of glass that is not needed. The only filters I own and use are Circular Polarizers and Netural Densitity filters and only when needed.
You are wrong though.
What does it better?
We often confuse personal anecdotes with FACT.
Screw the lens on BACKWARDS.
I'm asking if lens flare is really that much of a problem, on a 50mm lens no less, that would warrant the ordering of a lens hood.
You said:Please quote me where I said anything was "fact" if you would be so kind.
You Again said:That might be true, however how many times have you dropped a lens? I know I haven't.
And Here Again said:That might be true, however how many times have you dropped a lens? I know I haven't.
And I'm sure that is a great idea. Especially in the case of hoods that go outward.
I suggest you re-read this entire thread. Then search more. You (and a couple others) that cite that hoods are a PITA haven't a clue on how much they can protect and how much lesser filters can take away from your image. If they take up too much space, buy a larger bag. If YOU think hoods interfere with filters, then perhaps YOU should consider YOUR techniques. The only possible filter I can think of that would "interfere" is a circular polarizer. This is only inhibited by lack of practice. My CPL is a slim B+W and I can rotate it with ease and avoid fingerprints even with the very deep hood on my 70-200mm. Sorry, but I disagree with you. Unless I'm at a dirt track (or similar) where debris is likely to fly into my front element, I do not use a "protective" filter. I can garauntee you that when you have several thousand dollars worth of lenses, you too, will be mindfull of what you carry in your hands. The hood is priceless.I don't believe so. Lens hoods may prevent lens flare, but I already said that, and it doesn't do it significantly. UV filters protect from dust, dirt, scratches, and other kinds of crap. All a lens hood will protect you from is banging the lens on something, and even in that case it don't work if that something is skinnier than the opening of the hood. Hoods also interfere with filters, and some can be frustrating to store. In my opinion, a UV filter is much better in terms of protection than a hood. And in all my outdoor shooting, I've only had one lens flare problem. Hoods can take up too much space for just that. Its a simple accessory, and definitely not a necessity.
What does a pencil cost these days? Fifty cents? Ever drop one of those? It always amazes me that people can drop, bump or knock off something as small and simple as a pencil and figure they can completely control every situation with expensive equipment or vehicles. Get back with me in 30 years and tell me how that all worked out for you.=anubis404;1443018]That might be true, however how many times have you dropped a lens? I know I haven't. A filter provides more practical protection from dust, small bumps, dirt, and scratches. I doubt many photographers walk around full on dropping their lenses.
No were are talking about buying the manufactures designed OEM hood for each specific lens. Not one of them is a screw on lens hood. Nor are they the rubber fold down jobs. Aftermarket hood for the most part are a joke with the exception of the OEM rip off hoods that are direct copies of the manufactures hood at a cheaper price. My hoods are the proper OEM piece of equipment designed specifically for the lens they will go on. The only lens I do not always use the OEM hood on is my 400mm f2.8. Some events require a rubber hood for player safety. I have a proper sized, proper length of rubber plumbing boot that I use at those venues. Other wise I am using the $600 OEM hood.And even so, were talking about screw on lens hoods, which means the filter thread will be ruined anyway.
Me I choose to go with the best image quality rather than a false sense of protection. I don't put cling wrap on my car's windshield cause I don't want to have to wash it and I don't put unnecessary glass in front of my lens. Especially cheap glass. If I didn't own L glass or quality glass I would definately not be putting some piece of cheap glass in front of it. Image quality can be the difference between "that's a nice picture" and "Wow!"If I owned L class, I would too. I do use a hood, however IMO they are best used in combination. If I had to choose, I would definitely go with a filter.
Without the lens hood that light was causing some MAJOR issues in that shot... WITH the hood on it had absolutely zero effect.
