Lines
Thanks Ed. Reflections and shadow patterns like this aren't my strong suit but I'm seeing them more and more.
Once you've started noticing these you won't be able to stop. Hang on!
I like this. Nice work! :icon_thumbsup:
Love these kinds of geometrical, textural shots. This one is really well done, Ron. :thumbyo:
The most interesting part of the photo I think is the upper portion where the pattern of lines goes one way then the other... I wonder if it would look better if it didn't keep coming forward quite so far. I might make copies and play around with some different crops (not necessarily huge, seems like someone says 'crop' and people whack off way too much! lol) and see how it might look with a little less foreground (where the leaves more close up seem to get larger). Judgement call I think on how you balance one set of lines with the other and how much or how little to have in the frame.
I'd adjust the contrast too, to get a 'black' black and a 'white' white with a range of grays in between.
Very nicely done. Keep at it, you definitely seem to be on the right track.
Thank you.
Thank you.
Thank you. I did crop this some. I played with cropping out the hand rail that made the first lines before deciding on this crop. I was also struggling with how much of the top lines to keep on this one.
Like it very much !
Thanks Sashbar. I will play with that a little this evening.
