JohnS.
- Joined
- Jul 9, 2008
- Messages
- 330
- Reaction score
- 20
- Location
- New York, USA
- Can others edit my Photos
- Photos OK to edit
I always tell people to search for information whenever I'm on my automotive forums so I try to go by what I preach. And please bare in mind I am extremely new to photography. I have never used any form of external flash nor do I know anything about them until now.
With that being said, I'd like some input on the SB-600. I'm just a casual photographer. You can see my gear in my signature. The reason why I'm looking to get the 600 is for indoor use (which is 99% of the pictures I currently take with winter rolling in). I was at my cousins house yesterday for Thanksgiving and even though I was shooting @ ISO 400, 1/60sec, and f/1.8 in decent lighting, the pictures were still turning out darker than I expected. Plus, after seeing a lot of my recent photos taken inside my house, a lot of them are dark at f/1.8 and ISO 400 (I do not want to go any higher on the ISO since it's only the D40 and the noise gets noticeably and 100x worse at ISO 800 and higher. That and I suck at editing which I'm also trying to learn).
So I've spent the last hour or 2 reading up on the SB-600. Here is what I have gathered and my questions:
- The tilt and swiveling head is a HUGE plus for me, as I like to mix up the angle that I shoot. But does constantly pivoting the head make it wear out faster? Or can it even break if you're in a hurry and change it too fast?
- I read something about it only working up to 85mm zoom? Does that mean it doesn't work if you zoom past 85mm? Or is it just not effective past 85mm zoom?
- I also read that it doesn't come with a bounce card but taping an index card essentially does the same thing? Any downfalls to having to manually tape something on there or is there something I can buy?
- Is it worth buying a bounce dome? I saw pictures where the flash was bounced up 90º with a bounce dome and without one and then with a flash card with no dome. I realize they all create different effects. For example - 90º bounce with a flash card is "harder" light but the bounce fills in as usual while the flash card acts as a front fill and a bounce dome softens the light. I don't like hard shadows (ie - on camera flash) and this is another reason why I want an external flash besides more light.
- The SB-600 will not work past a 1/500 shutter speed on the D40? Not that I would use it past that anyways since I'm not really at a level where I want to flash fill in daylight.
- Although a big advantage over the 400 is the fact that you can control the flash output power, how annoying is it to have to constantly change the settings? I would assume depending on light availability, camera angles, locations, etc., that you would have to constantly change the settings to fulfill the desired amount of flash output.
I considered the SB-400 but I want to be able to have more control of the flash strength instead of just having an on/off switch. The SB-800 is way out of my price range considering I just dumped nearly 2 paychecks on 2 prime lenses, a couple filters and caps, and a new bag (yeah I don't make that much money).
Any input is appreciated. And I apologize if I missed anything in my research. But I like to be thorough before purchasing stuff.
