djacobox372
- Joined
- May 4, 2008
- Messages
- 2,925
- Reaction score
- 129
- Location
- Seattle, WA
- Can others edit my Photos
- Photos NOT OK to edit
Your fastest lens is about f4, if you were to upgrade to a lens that was f2 or faster you would achieve a two stop increase in low light performance. Of course you would also lose DOF as you go to wider apertures, which may or may not be desirable.
By comparison the D7000 is about 3 stops better then the D40 in low light performance.
I would start with the glass and flash--a 35mm f1.8 af-s is an excellent choice for either a d40 or d7000, as is a Sb-600. You may find that when you add those two things to your kit you may end up not needing the D7000 just yet, allowing you to extend the life of your d40.
