bratkinson
- Joined
- Dec 4, 2011
- Messages
- 1,643
- Reaction score
- 318
- Location
- Western MA
- Can others edit my Photos
- Photos OK to edit
I've been battling low light, no flash photography for years.
As mentioned above, raise the ISO, take the noise. I'd probably go to 1600 on the T3i. That was my 'OK noise' level when I had a 60D. Try some test shots at home at 1600 and see what you think about the noise. Check out ISO 800 and 3200 too. You never know until you try it with what you have.
As mentioned above, a 'fast' lens such as f1.4 would be a great help, at the 'cost' of thin DOF. An f2.8 lens might be a better, lower cost choice. But then, the 'nifty fifty' 50mm 1.8 can be had for about $100. Any smaller aperture such as the kit glass provides will seriously limit your results and force some very looonnnngggg exposures...like 1/20 or so...near impossible to handhold with any motion blurring.
So, the next step is a monopod. They're easy to carry and not terribly 'intrusive' or 'obstructing' to others. Leave it attached to the camera, but collapse it down when walking around with it. Be sure to practice all the other 'steadying' techniques as well...breath out 1/2 and hold it, lean against a wall, or even sit on a chair if possible, etc. You'll likely end up with shutter speeds in the 1/10 - 1/30 range, so no matter what, a good number will be blurred. Not even IS can fix things perfectly at those slow speeds.
Lastly, be willing to underexpose by about a 1/2 stop. Perhaps even a full stop if there aren't any too dark areas in the frame that would lose all detail if underexposed. I'd even consider having a pocket flashlight and having someone hold it on the subject area to light it up a bit, as well. You can easily increase the exposure in post processing without much 'obvious' degradation in IQ.
For what it's worth, I'm considering a trip to the Smithsonian Institution in Washington DC and this has got me to thinking about how I'd shoot it...
