Macro lens to G11?
.... Do you have flashes? SB-600 or SB-800? What bodies do you use...are they bodies with CLS/Commander mode? ....
I would advise against CLS with reflective objects at close range. The pre-flash does effect the subject. See this post......
http://www.thephotoforum.com/forum/...7323-using-sb-600-wirelessly.html#post1943300
An alternative is to reverse fire the flash (on hotshoe) into a reflector behind you (an assistant would be helpful) if you don't have RF triggers for off camera flash.
Good point.....just throw this on the hot shoe to fix that problem.
Nikon SG-3IR IR Panel for Camera Built-In Flashes 4905 - B&H
