Far as I'm aware there are no "true macro"* lenses on the current market which are zoom capable**. Thus the only macro lenses that will give you "true macro" are going to be prime (single focal length) lenses.
It's also important to remember that since magnification is based upon a ratio of "Size of the subject reflected on the sensor by the lens : Size of the subject in real life" and since we are taking true macro as 1:1 magification; this means that the frame content will be the same no matter what focal length of macro lens you use. When focused to the same magification at their closest focusing distance they achieve that 1:1 ratio and thus the frame content is the same.
Note that you will see a difference in background blurring; with longer focal length lenses blurring details more readily whilst shorter focal length have a smoother gradient. This can mean that sometimes short focal length macro lenses, with the right angle of shot, can appear to have more depth of field; this is not the case and depth of field remains the same (at 1:1 magnification) no matter the focal length.
The final thing that changes is the minimum focusing distance*** which in turn affects the working distance ****. The longer a focal length is the longer the minimum focusing distance is; which typically results in increased working distance as a result.
This latter point starts to impose practical limitations; for example I generally say nothing shorter than 60mm is viable for a macro lens for 1:1 work; and that in general you want to be at least at 90mm or longer when starting out. Shorter focal lengths like the various 60mm and 70mm options are good lenses, but the working distances are closer and more tricky in many ways; as is lighting as its gets easier to shadow the subject when working that close.
Optically speaking macro lenses are sharp. First and 3rd party (Tamron, Sigma, Tokina) options are top rate and whilst the own brand tend to have better AF performance; the 3rd party can more than equal on the optics front.
Not for reference and a rough guide.
1:2 (or 0.5:1 or half life size) is about the best the "zoom macro" like the 70-300mm lenses can get to'; and many can't even get that far
In visual terms :
1:2
And 1:1
As you can see its a huge difference
*Whilst there might be no official term the 1:1 magnification ratio is generally the best there is to measure it by.
**Technically a lot of macro lenses DO change their focal lengths as they focus closer, however this isn't reported to the user. It's also something a lot of regular lenses do as well and in general is a technical detail most ignore barring in reviews and side by side comparisons of some gear.
***Distance from the subject to the sensor/film in the camera
****Distance from the subject to the front of the lens
