I have the SensorScope...it works splendidly.
I'm not sure how this is better than just shooting an "overexposed" shot of the sky at f/11 or f/16. That shows if something is actually affecting the image.
It allows one to literally SEE the sensor surface (well, the AA filter array on most cameras), and to actually "see" where stuff happens to be on the sensor. The light it provides, and the way the light hits the sensor surface gives you a very good visual idea of what you're dealing with before swabbing the sensor. It also allows you to easily see evaporated sensor fluid, or cleaning streaks on the sensor surface. It's basically a magnified, well-lighted look at the sensor that's many times clearer than what the human eye can provide. It works better than one might imagine. But it's always nice to know that somebody who doesn't own one thinks it's useless. It's called a "tool". The SensorScope provides visual information that the unaided eye cannot yield, so you can literally "SEE" where problem areas are, and can take care of any problem issues with knowledge gained BEFORE the cleaning operation is done--whether that cleaning operation happens to be a few blasts of a blower bulb, or a wet swap, or a dry swap, or an Arctic Butterfly cleaning,etc. It's kind of like using a magnifying glass when removing a sliver, as opposed to simply sucking on the sliver with one's mouth for an day or so, until the sliver pops out.
