Joshonator
- Joined
- Apr 10, 2011
- Messages
- 164
- Reaction score
- 11
- Location
- Canada
- Can others edit my Photos
- Photos OK to edit
So I was bidding on two auctions on ebay and accidentally ended up winning them both, so I have two very similar lenses and will be selling one to my cousin.
The optical quality is pretty much identical between the two. Right now I'm leaning toward the 80-210 because the filter thread is very important to me for mounting hoods (the glass elements are under 4mm from the front) and I would like to try mounting a reverse 28mm lens to the front for macro. But I can't help thinking that I will miss the 70-80mm range.
I am probably going to try fixing the filter thread on the 70-210 myself but my efforts so far have failed. The "macro" capabilities of both lenses is pretty much the same.
The first one is a tamron adaptall 2 70-210 f3.8-4 Tamron Adaptall-2 70-210mm F/3.8-4 Model 46A
- 10mm better focal range
- the filter thread is slightly bent at one point, right now mounting filters is impossible
- partly plastic construction
- slightly lighter
- the zoom creeps
- In good condition other than two small marks on the focus ring
- the rear element looks slightly bigger leading me to think it may be slightly better in light performance.
- all metal construction
- slightly heavier
- in very good condition but there are a few small paint chips and the screws are slightly rusted
- zoom does not creep
- has more detailed focus marking on the barrel (I don't use these often)
