Metering mode for dark-ish room
jjd228
United States
I'm going to a convention next week and there will be a show of sorts happening on a stage in a fairly dark auditorium. I'll be down in the crowd and I'm wondering what metering mode I should use. Or, what metering mode would you instinctively start with in this situation, and why?
Thanks!
When I shoot pageants or graduations in a theater situation I usually bump ISO up to ~1600 to start f2.8 on a 70-200f2.8 and try to keep my shutter speed around 1/200 as possible. Spot metering gives me the best results while metering on my subject's face. Surprisingly I get decent results and am able to use a lower ISO when stage lighting is halfway decent.
Stage LIGHTING can often be quite intense and bright! You can easily be fooled, if you are sitting in the dark, and the stage and its people are all lighted. The single BIGGEST PROBLEM with shooting things that are up on a lighted stage is OVER-exposure caused by a meter that "sees" a large expanse of dark curtains, or dark set. Red velvet drapes, blue velvet drapes, black velvet drapes, black-painted stage walls, all of those things can easily be eight to 10 f/stops darker than somebody who is 15 feet in front of the curtain, and happens to be lighted by a spot or strong floodlight.
"Many" cameras will tend to over-expose the actors/pitchmen/speakers when the lens is set to wider-angle views; the speakers/actors might be 5% of the total picture area, and if the background is 90% dark,well, you can get some MASSIVE burn-out on people. With a longer, more-telephoto lens, light meter readings that do not include so doggone much dark background--are usually more-reliable meter readings.
If you ARE in an AUTO mode, and shooting with a short, wide-angle lens you might have to dial in Minus Exposure Compensation, as much as 3 stops, or more--if the STAGE and background are really dark, and the people are lighted up really brightly.
If you are shooting telephoto shots...you ought to be able to get more or less accurate readings using center-weighted, or semi-spot readings. If the lighting is the same for the whole show, you can arrive at the "right" exposure one time, using either exposure comp in an auto mode, or manual metering in spot, or trial-and-error, and then just shoot at the same exposure value for the whole show.
If the lighting is gonna Yo-Yo like,well, a Yo-Yo, with multi-colored spots and floods and scene changes constantly...you might really consider going to AUTO ISO mode, center-weighted metering, picking a HIGH maximum, like 3,200 ISO, and a shutter speed that is likely to be motion-stopping and lens-shake stopping, like say 1/100 second, and then letting the camera's AUTO ISO keep you adjusted as the lights swing back and forth.
I would use a hand-held meter to get a reading on the stage and then lock those settings into manual. I instinctively use manual mode because it enables greater consistency in exposure, especially when using flash. Metering is as subjective as art. There's no one right way. The best method is the one that works best for you. Every mode is valid. What matters is how you use it.
