monobath for rc paper
cyclops
Back in the 90s, I developed rc paper in a commercial monobath, whose name I cannot remember.
I can't find any monobaths for paper these days, so I have a question for you good folks.
Could I mix Dektol or Ilford developer and rapid fixer to make a monobath?
I've seen recipes online for monobaths using generic chemicals, but I am not a chemist.
Thanks
I had heard you could mix this up for film. I didn't seem to have any advantage over just doing the three steps. Same for paper, I have been able to put three trays in some very cramped locations. If you have to mix up three solutions and then mix those it is just adding another step. I would be interested in knowing what the advantage is to using the monobath.
simplicity, only one tray; cost, only one chemical, especially for short printing runs
Back in the late 1970's I devised a Monobath for a specialist industrial application and tested it with Ilfospeed RC papers and it worked extremely well, but Monobaths work best optinised for a specific product which was what we did. It was suggest that we sell it commercially by a consultant I used (he did some work for Alpha cameras and Elinchrom flash both then made in the same ex British TB clinic in Switzerland, his mother a member of the Lumière family).
I think Dan Qualls (maybe Quallis) posted a simple Monobath on APUG over 10 years ago, you can't use Rapid fixer but can add Ammonium or Sodium Thiosulphate to a developer which from memory is what Dan did, I think to HC-110.
It doesn't really work out any cheaper and there are archival issue without a separate fixer bath.
Ian
