My first long exposure pictures of water C&C please
john sherratt
okotoks calgary
Ok so yesturday i went out and took my first long exposure pictures of some water i dont think they turned out quite right. I need some input on my settings please i used manual and apature priroty mode when i was in manual i set my shutter speed but i set my apature i could not get my expourse meter to read 0. With out setting my shutter speed higher which i did not want to so as a beginner what did i need to do i'm thinking a ND filter would of brought my f stop down which would of helped sorry if it sounds stupid but just need some info as i want to get better at my hobby.
John, I like that last view of Elbow Falls. I am going to assume that the first two are upstream of the falls - the first one actually looks a little underexposed, whereas the last two are fairly well exposed. You are right that a ND filter will be a big help. I have photographed that falls a number of times over the years and have found that a 2 or 3 stop ND filter gives me decent results. If you are going to buy filters, I would suggest you look at some of the US suppliers (B&H) as I have found that filters are usually a lot cheaper in the US than they are in Canada - in any case, shop around a bit - prices do vary. My 0.02¢ FWIW.
WesternGuy
.........i'm thinking a ND filter would of brought my f stop down which would of helped.........
You need an ND filter to lengthen your shutter time. Leave the aperture where it is ( f/20 ), or open it more to the 'sweet spot'. Using a longer shutter speed will make the water even smoother.
FWIW, adjusting the white point and raising the left side of the curve (and upping the contrast a bit) on the first photo can really make it pop.
Yes it was Elbow falls WesternGuy and thank you for the edit 480 sparky thank you for both taking the time to give your input i appreciate it.
