My first moon shot
jcdeboever
Michigan
Never done one before. Looked up methodology and many confusing scenarios. So I went with what I understand currently and my thoughts were mostly correct. I guess that means I am learning. I think the next shots will be later in the night, maybe a full moon, and then a crescent. I tried f/8 though f/16. The f/11 ones seemed to be the sharpest. D3300, Sigma 150-600mm C. Tripod, remote, live view. No edit other than a crop. Sharpness was set in camera at 7. I am open for suggestions and/or comments.
ƒ/11.0, 0.0080 s (1/125), 100 ISO, single point focus, spot metering, auto WB.
I would have thought that 1/125th would have been too slow @ 600, but it worked well. Nice shot
Thanks. I started at 600 and immediately bumped it slower after seeing the dim moon. I would love to try it with a better camera just to see how different it could be. Pretty happy with it. I think changing locations, introducing other silhouettes around it will make it more interesting. Not really my forte, just exploring different things currently.
I think you mis-understood. I thought that at 600mm focal length on a crop camera, that there would be motion blur (the moon moving). But this is nice and sharp.
I did misunderstand. Informative comment though. Thanks for that.
Looking good. 2 days till full moon, hopefully no clouds!
Great first try !!
I was going to take photos of the moon last night at 2,500mm and 5,000mm
My puny Tamron 150-600 sits atop my telescope as a guiding scope at times.
But I fell asleep early :(
Thanks @astroNikon, @Rick50, @goooner, @ZombiesniperJr.
I checked into a 2X converter but they really recommend a semi pro or professional DSLR for it to work correctly. Maybe there is something else that would work but not sure, probably should check with @DarkShadow. Someone on here had a focus issue with it and sent it back, I think it was @dannylightning.
If you're ever around here at night, with the moon and no clouds we can throw my 2x TC on it and see what happens in Manual Focus.
Shoot, why don't we just put it on that behemoth telescope from NASA that you have. Shoot some aliens on plant xvectar.
nice shot. looks good
image stabilization would probably fix that, not sure if he was using it or not.. but yes generally you want a shutter speed faster than the zoom of the lens if your not using stabilization. so a shutter speed faster than 1/900 would be ideal on a crop sensor camera and no stabilization..
i had the new sigma 1.4 x converter that was designed to use with my lens, i did send it back, looks like there was a firmware update for the lens that made it play a little nicer with that converter that i did not know about till after i sent it back.
