My first "real" photo lighting...
BuS_RiDeR
Riverview, New Brunswick, Canada.
I'm getting my first lighting kit. Its an early Christmas Gift. :)
I am picking them up tomorrow. Next step: learning how to use them. :)
Take some pix w/ them. I personally hated them when I used at friend's house but I wanna get your feedback.
This is what my experience has been. They're just simply not bright enough, at all to be honest. I've used the ones with 3 bulbs with reflectors and even they weren't bright enough....
They're not 500w/s monolights for sure, but they're a lot better than nothing. New gear is always good - enjoy!
Interesting. Thanks for the input. I will deffinatly be doing some experimenting. Unfortunately I don't have the option to "try before I buy".
I may have to add an off camera flash or two... or maybe a softbox to the mix.. But I am very limited in cash. So this will be a start.
I'll post an example of the result... when I get the hang of it. :)
I started with these. Like others said they're not really bright enough, but I still use the stands and umbrellas.
From my understanding..... CF bulbs will give you omni-directional lighting. Meaning, it goes were it wants, not as you intended. Look at the image you posted. Think about it.
These are just continuous light bulbs on a light stand w/ umbrellas, no? They're not strobes, correct?
I got the same set and found that I didn't get enough light thru them for a main light. I got a 2 headed socket so I could use both bulbs in one umbrella and now use this for a fill light. Adjustable strobe and and the other shoot thru umbrella for the main light. The stands I got with the set are great.
You might also try replacing the CFLs with these if the buget permits; they're quite inexpensive.
