TCampbell
- Joined
- Mar 31, 2012
- Messages
- 3,614
- Reaction score
- 1,558
- Location
- Dearborn, MI
- Can others edit my Photos
- Photos OK to edit
Nice shots.
In #1, frame him a little lower (head higher in the frame) so you're not cutting off his arms. This is a good masculine pose for guys... head tilted back toward the lower shoulder.
In #2, avoid posing a subject with shoulders square to the camera. I also avoid placing a subject too close to a background unless the background is angle and provides leading lines to direct the view to the subject. Also... be _very_ careful when shooting into glass (reflections). I don't think I can see you in this shot though.
In #4, in addition to Tyler's comment (your rule of thirds placement has him facing out-of-frame... generally you want them to facing in toward the center of frame) the lower left corner is a bit of a distraction. There's something metal there (perhaps a gate) and the corner is a little distracting as well. I might have moved him farther down the wall and used the wall to create a leading line directing the vision toward your subject. In both #3 and #4 I wish you'd have cropped in a little closer.
I like #5 and I like that this is closer -- but I do agree with Tyler on that arm.
#6 has too much empty sky. I'd have lowered the camera. As I look at the lower corner details I might have gone for a full-length shot here and used the wall as a leading line (but then I can't see what that wall really looks like). His body is leaning quite a bit more than I'd like.
#7 His body is too far from the girl. Move their bodies closer. Bringing them closer and also having them gently tilt their heads together (but just gently) helps convey a warmer feeling... that they like each other.
#8 Nice facial emotion in this one!
