cynthiav99
- Joined
- Jun 24, 2012
- Messages
- 54
- Reaction score
- 9
- Location
- davenport, Iowa
- Can others edit my Photos
- Photos OK to edit
Yes, but without all the information it's hard to say where. When explaining your lighting set-up you need to reference it to the camera and subject, such as: "Key light: shoot-through umbrella, 3' from subject, 30 deg camera right 12" above subject's head, fill: second shoot-through, 5' from subject, 75 deg camera left, 1 stop below key". This way we can provide more accurate recommendations on ways to improve your set-up.lighting is two umbrellas and small light stand also natural light from 3 windows in the livingroom. Camera canon 60D and lens 18-135mm
so saying its too bright at one point I need to move the stands in a better place? I will be getting a soft box light and reflectors soon
I see two catch lights, but it looks as if you used the built-in flash for Fill because it is pretty much dead center in all shots. If your Main light is going through an umbrella, I believe you have it set too far away since its catch light is similar in size as the middle one. You are getting a Butterfly lighting effect, but I think your Fill light needs to be knocked down some, perhaps a quarter to half the power setting used.lighting is two umbrellas and small light stand also natural light from 3 windows in the livingroom.
