ND filters
Goldcoin79
Uk, Hemel Hempstead
Hi,
I have purchased the nikon D5100 with the twin kit lens (18-55 and 55-200mm vr lens) I want to by an ND filter probably for the 18-55mm lens so I can do some long exposure shots so looking for advice on buying filters as I have not bought any before.
The prices seem to vary quite a bit even though they say they both filter the same amount of light so what is the difference in a more expensive filter?
Can you damage a camera by using a wrong filter?
How does having a filter on effect the auto focus?
I was thinking of going for a 9 stop ND filter to do long exposures to catch movement in water and sky, does this sound correct?
Any advice is appreciated.
No, you can't damage the camera with a filter as long as it fits. 9 stops is quite a bit, but no reason it can't work for you
I thought of going for 9 stops as a lot of the pictures I see that get the nice creamy misty effect when shooting water seem to have used a9stop filter.
I purchased a B+W ND 9 stop from amazon for around $130. It's great for achieving that smooth silky look with things like water falls, flowing streams, etc.
One of my examples
Rock near the falls by Shefjr, on Flickr
I too am interested in getting some ND filters. Commenting to easily follow responses. :thumbup:
..........The prices seem to vary quite a bit even though they say they both filter the same amount of light so what is the difference in a more expensive filter?
Cheap filters will reduce the image quality more than an expensive one. Cheap filters will be mounted in plastic, good ones in metal.
.........Can you damage a camera by using a wrong filter?
Yes, but you really gotta try hard.... like cramming the filter into the camera after you remove the lens.
.....How does having a filter on effect the auto focus?
Get the image too dark, and AF might not work. Focus & compose, then install the filter.
....I was thinking of going for a 9 stop ND filter to do long exposures to catch movement in water and sky, does this sound correct?
Start with a 3 or 6 stop filter first.
I've been using the Hoya NDX400 for my long exposure. love it.
One of my examples
Nice shot!
To the OP, I think the main thing you need to keep in mind is that anytime you place additional pieces of glass between the light and the sensor, there is a potential for that additional piece to degrade your image quality. In other words, be wary of bargain basement filters.
I picked up one of these a few months ago:
Fader ND MK II
It’s not top of the line by any means but the consensus in reviews seems to be that it has a pretty decent bang-for-your-buck factor.
Results of my own preliminary testing have been positive in terms of sharpness, etc., but I’m reserving final judgment until I really get a chance to see what it can do.
What are some of the recommended brands? I've been eyeing B+W.
Are Tiffen good filters? (The price is low, but reviews are very positive)
Amazon.com: Hoya 77mm Neutral Density ND-400 HMC Filter: Electronics
how do you know how many stops a filter has?
Nevermind, I found the answer to my own question here: "The Ultimate Guide To Neutral Density Filters" by Peter Hill | Redbubble
great info read!
What did you decide to buy ?
great info read!
I still haven't pulled the trigger, but I'm leaning towards the Hoya 77mm 9stop.
The more expensive filters tend to be of better quality.
