ND for Drones
0ptics
WA
Hello,
I have the DJI Mavic Pro 1 and wanted to shoot long exposure waterfall drone pictures.
1) Is shooting at 1 sec with the Mavic too slow for a rushing waterfall during daylight? I want to get that silky smooth water motion blur but for everything else to be sharp.
2) Should I be using Tripod mode versus normal?
3) Seems like NDs go by 4, 8, 16, etc. Which individual ones or set should I get? I'd hate to waste battery life & time switching on and off different ND filters. Is there like a general rule (eg. harsh sun use 32, while overcast use 16).
Thanks!
Because prevailing light is so variable most people get a set of ND Filters. You may use a 10 one time and need a 10 + 5+4 the next time.
My first thought was that there was no way a drone could be held steady enough for a long exposure.
Concur. You may get useable images, but that will be about it. As good as drone technology is, a >1 sec exposure isn't going to be sharp. Air currents, minor corrections, etc, are going to result in sub-par images. As well, especially on larger water falls there are often unique localized air currents that will further complicate matters.
You know, after I posted that I did consider that the camera may be gyro-stabilized. It may work if that's the case but I don't know how well a system like that would work on a consumer-level item.
My first question would be........ is the camera on the drone even capable of long exposures?
