CThomas817
- Joined
- Aug 28, 2017
- Messages
- 143
- Reaction score
- 8
- Can others edit my Photos
- Photos OK to edit
Another option. I own this:
https://tokinausa.com/product/at-x-...MI4p3R0pSK2gIV0wOGCh1V6QZREAAYAiAAEgJfpvD_BwE
Pros? Cons?
sometimes I actually like to hear the lens focusing... some of my lenses I have no idea if they are actually focusing or not when they are so quite and moving in short distances that you cant pick up within the viewfinder.
I doubt any new-born images will actually reach true macro (1:1 on the sensor, or for most cameras less than 18mm). Even a shot of just the baby's hand is significantly bigger than this. So the images you're taking will technically be close-ups rather than macro.
Standard macro lenses will be good for this but many 'macro' zooms are also actually adequate. However I would opt simply for a set of extension tubes for a moderate telephoto, allowing closer than normal focus while not getting the lens so close to the baby as to disturb it. Splash out for a set that includes all the electronic connections & your typical 50-200 lens will cover anything your likely to need for new-born shots complete with AF. If you have a shorter focal length lens as well you'll be able to get to greater than life size if you do want the baby's fingerprints individually
My 50 & 85 primes as well as my 24-70 are typically my go-to lenses for any shots not involving high detail. I don't think I can invest in a 50-200 right now. Anything with macro capability whether a prime or zoom would be fine, just trying to do so on a budget. I will look into the extension tubes... thanks!
Pros? Cons?
Another budget option is closeup lens/filters, a set of 3 lenses.
The good thing is it does not decrease affect aperture, and the AF and auto functions of the lens still work.
I suggest starting with the weakest lens of the 3 in the kit, and see if that does the job.
The only issue is, what diameter to get, since you have several lenses.
THIS ^^^^. YES!, a hundred times, YES! I agree wholeheartedly, I often really,really,really like to hear, and feel that little "dzzt!" sound of an AF or AF-D Nikkor being driven to a new focus acquisition. And also, in a few instances, the AF-D screw-drive focusing lenses focus FASTER than the newer AF-S models; the 50/1.8 AF-S G and the 85/1.8 AF-S G are both somewhat slow-ish focusers; earlier AF-D 50 and 85 models focus faster. I agree 100%: at times, the silent AF-S lenses are sometimes so quiet,and there's no feel or feedback, that it's sometimes difficult to sense if the lens has actually acquired a new focus. I always shoot in AF-C mode, so to me, the screw-driven focusing lenses are something I'm A-okay with. On the high-end d-skr bodies with strong AF modules, the AF and AF-D Nikkors focus quite well, possibly because the newer, d-slr cameras are a decade, or two decades, or three decades newer than the early AF film Nikon SLR cameras and their old-time AF modules, around which those lenses were originally designed.
