theraven871
- Joined
- Jun 21, 2013
- Messages
- 82
- Reaction score
- 14
- Location
- United States
- Can others edit my Photos
- Photos NOT OK to edit
- Thread Starter 🔹
- #16
Is there much of a difference between the Canon T3 and the T3i?
Since nobody seemd to have directly addressed this:Am I to understand that Canon and Nikon lens' are not interchangeable?
This was very helpful information. Thank you!Since nobody seemd to have directly addressed this:Am I to understand that Canon and Nikon lens' are not interchangeable?
No, they are certainly not just trivially interchangeable (you couldn't take one off and put it on the other camera straight up in either direction).
However, Nikon lenses can be cheaply used on Canon bodies, with no optical drawbacks, via the use of a mechanical converter for the lens mount (~$70 for a decent basic one). However, you will be limited to manual focus and manual aperture. Since modern digital nikon lenses do not have aperture rings, this means those lenses will be extraordinarily difficult or impossible to use. Although I believe there is actually an adapter that lets you control aperture manually for G-series lenses, but I've never tried it.
In other words, if you use an adapter, you're pretty much restricted to older full manual lenses with aperture rings, and then of course manually focusing them.
And as for the reverse, Canon lenses CANNOT be used on Nikon bodies at all. There are adapters, but they need to add extra lenses to optically modify the image to allow focusing at infinity (you can't focus at infinity otherwise since the Nikon mount is physically further from the sensor). These lenses will degrade the quality of your image some degree no matter what, even if very well made. And the cheaper ones will butcher your image quality.
This was good to know, thank you!If you decide to upgrade to a full frame 5D or 6D later, your EF-S glass will be unusable.Also, if it makes any difference, my father is currently shooting with a Canon EOS 6D
